<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.013"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="read_database" compatibility="5.3.013" expanded="true" height="60" name="Read Database (2)" width="90" x="112" y="255"> <parameter key="connection" value="MySQLConnection"/> <parameter key="query" value="Select CEIL(COUNT(*)/%{mBatchSize}) as 'MyTableRecords' FROM MyTable"/> <enumeration key="parameters"/> </operator> <operator activated="true" class="extract_macro" compatibility="5.3.013" expanded="true" height="60" name="Extract Macro" width="90" x="246" y="255"> <parameter key="macro" value="mMyTableRecords"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="MyTableRecords"/> <parameter key="example_index" value="1"/> <list key="additional_macros"/> </operator> <operator activated="true" class="loop" compatibility="5.3.013" expanded="true" height="76" name="Loop" width="90" x="246" y="120"> <parameter key="iterations" value="%{mMyTableRecords}"/> <process expanded="true"> <operator activated="true" class="read_database" compatibility="5.3.013" expanded="true" height="60" name="Read Database (3)" width="90" x="45" y="120"> <parameter key="connection" value="MySQLConnection"/> <parameter key="query" value="Select CEIL(COUNT(*)/1000) as 'MyTableRecords' FROM MyTable LIMIT (%{mBatchStart}+1),(%{mMyTableRecords}*%{mBatchSize})"/> <enumeration key="parameters"/> </operator> <operator activated="true" class="subprocess" compatibility="5.3.013" expanded="true" height="76" name="SomeProcessing" width="90" x="246" y="75"> <process expanded="true"> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="generate_macro" compatibility="5.3.013" expanded="true" height="76" name="Generate Macro" width="90" x="45" y="300"> <list key="function_descriptions"> <parameter key="mBatchStart" value="%{mBatchSize} * %{mMyTableRecords}"/> </list> </operator> <connect from_op="Read Database (3)" from_port="output" to_op="SomeProcessing" to_port="in 1"/> <connect from_op="SomeProcessing" from_port="out 1" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Generate Macro" from_port="through 1" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="set_macros" compatibility="5.3.013" expanded="true" height="60" name="Set Macros" width="90" x="45" y="165"> <list key="macros"> <parameter key="mBatchStart" value="0"/> <parameter key="mBatchSize" value="1000"/> </list> </operator> <connect from_op="Read Database (2)" from_port="output" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Loop" to_port="input 1"/> <connect from_op="Loop" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
