<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.4.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process"> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="generate_transfer_data" compatibility="6.4.000" expanded="true" height="60" name="Generate Transfer Data" width="90" x="45" y="75"/> <operator activated="true" class="set_macro" compatibility="6.4.000" expanded="true" height="76" name="Set Macro" width="90" x="179" y="30"> <parameter key="macro" value="ATTRIBUTE"/> <parameter key="value" value="Amount"/> </operator> <operator activated="true" class="numerical_to_polynominal" compatibility="6.0.003" expanded="true" height="76" name="Numerical to Polynominal" width="90" x="313" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="%{ATTRIBUTE}"/> </operator> <operator activated="true" class="generate_attributes" compatibility="6.4.000" expanded="true" height="76" name="Generate Attributes" width="90" x="447" y="30"> <list key="function_descriptions"> <parameter key="digit" value="cut(%{ATTRIBUTE},0,1)"/> <parameter key="digit_complex" value="floor(parse(%{ATTRIBUTE})/pow(10,floor(log(parse(%{ATTRIBUTE})))))"/> </list> </operator> <operator activated="true" class="aggregate" compatibility="6.0.006" expanded="true" height="76" name="Aggregate" width="90" x="246" y="120"> <list key="aggregation_attributes"> <parameter key="digit" value="count (fractional)"/> </list> <parameter key="group_by_attributes" value="digit"/> </operator> <operator activated="true" class="filter_examples" compatibility="6.4.000" expanded="true" height="94" name="Filter Examples" width="90" x="380" y="120"> <list key="filters_list"> <parameter key="filters_entry_key" value="digit.does_not_equal.0"/> </list> </operator> <operator activated="true" class="generate_attributes" compatibility="6.4.000" expanded="true" height="76" name="Generate Attributes (2)" width="90" x="514" y="120"> <list key="function_descriptions"> <parameter key="benford" value="log(1+1/parse(digit))"/> </list> </operator> <connect from_op="Generate Transfer Data" from_port="output" to_op="Set Macro" to_port="through 1"/> <connect from_op="Set Macro" from_port="through 1" to_op="Numerical to Polynominal" to_port="example set input"/> <connect from_op="Numerical to Polynominal" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Generate Attributes (2)" to_port="example set input"/> <connect from_op="Generate Attributes (2)" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
