I have a folder with several csv files... along with some other files. What I want to do is loop through only the files that match the following case insensitive filter:
bdo*26*.csv
I can not figure out how to get any filter working. The code below is what I am trying to run just to verify funcitonality and right now I am not even able to filter just csv files. if I leave the filter blank it reads in all the files (including those I don't want). so the read is apparently working. what am I doing wrong in the filter?
any help is appreciated, thanks
Greg
<process version="5.3.013">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="loop_files" compatibility="5.3.013" expanded="true" height="76" name="Loop Files" width="90" x="179" y="120">
<parameter key="directory" value="C:\Users\greg.mcfadden\Desktop\Allen\temp"/>
<parameter key="filter" value="=*.csv"/>
<operator activated="true" class="read_csv" compatibility="5.3.013" expanded="true" height="60" name="Read CSV" width="90" x="246" y="255">
<parameter key="column_separators" value=","/>
<list key="annotations"/>
<parameter key="1" value="a.true.nominal.regular"/>
<parameter key="2" value="b.true.nominal.regular"/>
<parameter key="3" value="c.true.nominal.regular"/>
<parameter key="4" value="d.true.nominal.regular"/>
</list>
<connect from_port="file object" to_op="Read CSV" to_port="file"/>
<connect from_op="Read CSV" from_port="output" to_port="out 1"/>
<portSpacing port="source_file object" spacing="0"/>
</process>
<connect from_op="Loop Files" from_port="out 1" to_port="result 1"/>
</process>
</process>
