<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.6.000-SNAPSHOT"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.6.000-SNAPSHOT" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.6.000-SNAPSHOT" expanded="true" height="60" name="Retrieve Deals" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Deals"/> </operator> <operator activated="true" class="log" compatibility="6.6.000-SNAPSHOT" expanded="true" height="76" name="Log" width="90" x="179" y="30"> <list key="log"> <parameter key="test" value="operator.Retrieve Deals.parameter.repository_entry"/> </list> </operator> <operator activated="true" class="log_to_data" compatibility="6.6.000-SNAPSHOT" expanded="true" height="94" name="Log to Data" width="90" x="313" y="30"> <parameter key="log_name" value="Log"/> </operator> <connect from_op="Retrieve Deals" from_port="output" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_op="Log to Data" to_port="through 1"/> <connect from_op="Log to Data" from_port="exampleSet" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
