🎉Community Raffle - Win $25
Join and Win
How to use Log operator within RapidMiner server process
User: "kypexin"
New Altair Community Member
Updated by Jocelyn
Hi rapidminers,
I have a trouble with using Log operator in the process which I run on RapidMiner server. I want to log some parameters from Optimize Parameters operator in a standard way to compare performance for, like, 20 iterations.
The operator offers to specify a filename but it is a path on the local machine only. If I run the process on the server, the local path is not resolved and no log file is written finally.
Any hint about how to write log file from within a server process?
