<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.013"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="read_csv" compatibility="5.3.013" expanded="true" height="60" name="PTA LOG" width="90" x="45" y="30"> <parameter key="csv_file" value="C:\Users\greg.mcfadden\Desktop\Allen\SystemModeling\node_37_08202013_pta_log.csv"/> <parameter key="column_separators" value=","/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <parameter key="encoding" value="windows-1252"/> <list key="data_set_meta_data_information"> <parameter key="0" value="Date/Time.true.text.attribute"/> <parameter key="1" value="Drive Voltage (VDC).true.real.attribute"/> <parameter key="2" value="Current (A_rms).true.real.attribute"/> <parameter key="3" value="Power (W).true.real.attribute"/> <parameter key="4" value="Heater Head Temp (degC).true.real.attribute"/> <parameter key="5" value="Heater Head Temp Setpoint (degC).true.real.attribute"/> <parameter key="6" value="Generator Voltage (ADC Counts).true.real.attribute"/> <parameter key="7" value="DC Voltage (VDC).true.real.attribute"/> <parameter key="8" value="Hall Sensor Counter.true.real.attribute"/> <parameter key="9" value="Generator State.false.binominal.attribute"/> <parameter key="10" value="Pump Set Speed.true.real.attribute"/> <parameter key="11" value="Pump Actual Speed.true.real.attribute"/> <parameter key="12" value="Pump Voltage.true.real.attribute"/> <parameter key="13" value="Pump Current.true.real.attribute"/> <parameter key="14" value="Pump Coolant.true.real.attribute"/> <parameter key="15" value="Pump Error Byte 1.true.real.attribute"/> <parameter key="16" value="Pump Error Byte 2.true.real.attribute"/> <parameter key="17" value="Pump Error Byte 3.true.real.attribute"/> <parameter key="18" value="Steering Temperature Top.true.real.attribute"/> <parameter key="19" value="Steering Temperature Right.true.real.attribute"/> <parameter key="20" value="Steering Temperature Bottom.true.real.attribute"/> <parameter key="21" value="Steering Temperature Left.true.real.attribute"/> <parameter key="22" value="Azimuth Offset (deg).true.real.attribute"/> <parameter key="23" value="Zenith Offset (deg).true.real.attribute"/> <parameter key="24" value="Azimuth Position (deg).true.real.attribute"/> <parameter key="25" value="Zenith Position (deg).true.real.attribute"/> <parameter key="26" value="Status Data.true.real.attribute"/> <parameter key="27" value="Fault Data.true.real.attribute"/> <parameter key="28" value="HCMOffset.true.real.attribute"/> <parameter key="29" value="Debug Value 2.true.real.attribute"/> <parameter key="30" value="Debug Value 3.true.real.attribute"/> <parameter key="31" value="Debug Value 4.true.real.attribute"/> <parameter key="32" value="Version Number.true.real.attribute"/> <parameter key="33" value="Update Counter.true.real.attribute"/> <parameter key="34" value="Fault Details.true.real.attribute"/> <parameter key="35" value="att36.false.attribute_value.attribute"/> </list> </operator> <operator activated="true" class="generate_attributes" compatibility="5.3.013" expanded="true" height="76" name="Generate Attributes" width="90" x="179" y="30"> <list key="function_descriptions"> <parameter key="HCMOFFSET2" value="if(HCMOffset>1000,HCMOffset-65536,HCMOffset)"/> </list> </operator> <operator activated="true" class="set_role" compatibility="5.3.013" expanded="true" height="76" name="Set Role" width="90" x="313" y="30"> <parameter key="attribute_name" value="Date/Time"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="read_csv" compatibility="5.3.013" expanded="true" height="60" name="DAQ LOG" width="90" x="45" y="120"> <parameter key="csv_file" value="C:\Users\greg.mcfadden\Desktop\Allen\SystemModeling\GH37-2013-08-20.CSV"/> <parameter key="column_separators" value=","/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <parameter key="encoding" value="windows-1252"/> <list key="data_set_meta_data_information"> <parameter key="0" value="Date (UTC).true.text.attribute"/> <parameter key="1" value="Time (UTC).true.text.attribute"/> <parameter key="2" value="Raw Timestamp.true.real.attribute"/> <parameter key="3" value="Date (Local).true.binominal.attribute"/> <parameter key="4" value="Time (Local).true.polynominal.attribute"/> <parameter key="5" value="PowerDish Unit ID.true.binominal.attribute"/> <parameter key="6" value="KN Q1.true.real.attribute"/> <parameter key="7" value="KN Q12.true.real.attribute"/> <parameter key="8" value="KN Q2.true.real.attribute"/> <parameter key="9" value="KN Q23.true.real.attribute"/> <parameter key="10" value="KN Q3.true.real.attribute"/> <parameter key="11" value="KN Q34.true.real.attribute"/> <parameter key="12" value="KN Q4.true.real.attribute"/> <parameter key="13" value="KN Q41.true.real.attribute"/> <parameter key="14" value="HHX Q12.true.real.attribute"/> <parameter key="15" value="HHX Q23.true.real.attribute"/> <parameter key="16" value="HHX Q34.true.real.attribute"/> <parameter key="17" value="HHX Q41.true.real.attribute"/> <parameter key="18" value="Center.true.real.attribute"/> <parameter key="19" value="Open M3C1.true.real.attribute"/> <parameter key="20" value="Open M3C2.true.real.attribute"/> <parameter key="21" value="IR.true.real.attribute"/> </list> </operator> <operator activated="true" class="generate_concatenation" compatibility="5.3.013" expanded="true" height="76" name="Generate Concatenation" width="90" x="179" y="120"> <parameter key="first_attribute" value="Date (UTC)"/> <parameter key="second_attribute" value="Time (UTC)"/> <parameter key="separator" value=" "/> </operator> <operator activated="true" class="nominal_to_text" compatibility="5.3.013" expanded="true" height="76" name="Nominal to Text" width="90" x="313" y="120"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Date (UTC) Time (UTC)"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.3.013" expanded="true" height="76" name="Select Attributes (2)" width="90" x="447" y="120"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|Date (UTC) Time (UTC)|Center|PowerDish Unit ID|Open M3C2|Open M3C1|KN Q41|KN Q4|KN Q34|KN Q3|KN Q23|KN Q2|KN Q12|KN Q1|IR|HHX Q41|HHX Q34|HHX Q23|HHX Q12"/> </operator> <operator activated="true" class="set_role" compatibility="5.3.013" expanded="true" height="76" name="Set Role (2)" width="90" x="581" y="120"> <parameter key="attribute_name" value="Date (UTC) Time (UTC)"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="join" compatibility="5.3.013" expanded="true" height="76" name="Join" width="90" x="782" y="75"> <list key="key_attributes"/> </operator> <operator activated="true" class="read_csv" compatibility="5.3.013" expanded="true" height="60" name="WEATHER LOG" width="90" x="45" y="255"> <description>Must preprocess weather file using excel weatherfileadjuster and save as csv</description> <parameter key="csv_file" value="C:\Users\greg.mcfadden\Desktop\Allen\SystemModeling\WeatherFileAdjuster.csv"/> <parameter key="column_separators" value=","/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <parameter key="encoding" value="windows-1252"/> <list key="data_set_meta_data_information"> <parameter key="0" value="Date/Time.true.text.attribute"/> <parameter key="1" value="Wind Spd\. (Med).true.real.attribute"/> <parameter key="2" value="Wind Dir\. (Med).true.real.attribute"/> <parameter key="3" value="Air\.Temp\. (Med).true.real.attribute"/> <parameter key="4" value="Rel\. Hum\. (Med).true.real.attribute"/> <parameter key="5" value="Atm\.Pressu (Med).true.real.attribute"/> <parameter key="6" value="DirectRad1 (Med).true.real.attribute"/> <parameter key="7" value="DirectRad1 (Max).true.real.attribute"/> <parameter key="8" value="DirectRad1 (Min).true.real.attribute"/> <parameter key="9" value="Solar Elev (Med).false.integer.attribute"/> <parameter key="10" value="Solar Elev (Max).false.integer.attribute"/> <parameter key="11" value="Solar Elev (Min).false.integer.attribute"/> <parameter key="12" value="Solar Az\. (Med).false.real.attribute"/> <parameter key="13" value="Solar Az\. (Max).false.real.attribute"/> <parameter key="14" value="Solar Az\. (Min).false.real.attribute"/> <parameter key="15" value="Rain (Acu).false.integer.attribute"/> <parameter key="16" value="Battery (Med).false.real.attribute"/> <parameter key="17" value="Battery (Max).false.real.attribute"/> <parameter key="18" value="Battery (Min).false.real.attribute"/> </list> </operator> <operator activated="true" class="set_role" compatibility="5.3.013" expanded="true" height="76" name="Set Role (3)" width="90" x="112" y="435"> <parameter key="attribute_name" value="Date/Time"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="multiply" compatibility="5.3.013" expanded="true" height="76" name="Multiply (5)" width="90" x="246" y="255"/> <operator activated="true" class="join" compatibility="5.3.013" expanded="true" height="76" name="Join (2)" width="90" x="380" y="390"> <parameter key="join_type" value="outer"/> <list key="key_attributes"/> </operator> <operator activated="true" class="replace_missing_values" compatibility="5.3.013" expanded="true" height="94" name="Replace Missing Values" width="90" x="514" y="390"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|Zenith Position (deg)|Zenith Offset (deg)|Wind Spd. (Med)|Wind Dir. (Med)|Rel. Hum. (Med)|DirectRad1 (Min)|DirectRad1 (Med)|DirectRad1 (Max)|Azimuth Position (deg)|Azimuth Offset (deg)|Atm.Pressu (Med)|Air.Temp. (Med)"/> <parameter key="default" value="value"/> <list key="columns"/> <parameter key="replenishment_value" value="0"/> </operator> <operator activated="true" class="rename_by_replacing" compatibility="5.3.013" expanded="true" height="76" name="Rename by Replacing (2)" width="90" x="648" y="390"/> <operator activated="true" class="set_role" compatibility="5.3.013" expanded="true" height="76" name="Set Role (5)" width="90" x="782" y="390"> <parameter key="attribute_name" value="Date/Time"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_id" compatibility="5.3.013" expanded="true" height="76" name="Generate ID (2)" width="90" x="916" y="390"/> <operator activated="true" class="multiply" compatibility="5.3.013" expanded="true" height="94" name="Multiply (6)" width="90" x="179" y="570"/> <operator activated="true" class="select_attributes" compatibility="5.3.013" expanded="true" height="76" name="Select Attributes (4)" width="90" x="313" y="660"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="HHXQ12|HHXQ23|HHXQ34|HHXQ41|KNQ1|KNQ12|KNQ2|KNQ23|KNQ3|KNQ34|KNQ4|KNQ41||id"/> </operator> <operator activated="true" class="replace_missing_values" compatibility="5.3.013" expanded="true" height="94" name="Replace Missing Values (2)" width="90" x="447" y="660"> <parameter key="default" value="value"/> <list key="columns"/> <parameter key="replenishment_value" value="0"/> </operator> <operator activated="true" class="generate_attributes" compatibility="5.3.013" expanded="true" height="76" name="Generate Attributes (2)" width="90" x="581" y="660"> <list key="function_descriptions"> <parameter key="MAXHHX" value="max(HHXQ12,HHXQ23,HHXQ34,HHXQ41)"/> <parameter key="MAXKNUCK" value="max(KNQ1,KNQ12,KNQ2,KNQ23,KNQ3,KNQ34,KNQ4,KNQ41)"/> </list> </operator> <operator activated="true" class="select_attributes" compatibility="5.3.013" expanded="true" height="76" name="Select Attributes (5)" width="90" x="715" y="705"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|id|MAXKNUCK|MAXHHX"/> </operator> <operator activated="true" class="declare_missing_value" compatibility="5.3.013" expanded="true" height="76" name="Declare Missing Value" width="90" x="313" y="570"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|KNQ41|KNQ4|KNQ34|KNQ3|KNQ23|KNQ2|KNQ12|KNQ1"/> <parameter key="numeric_value" value="0.0"/> </operator> <operator activated="true" class="filter_examples" compatibility="5.3.013" expanded="true" height="76" name="Filter Examples (2)" width="90" x="447" y="570"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="PowerW>100"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.3.013" expanded="true" height="76" name="Select Attributes (3)" width="90" x="581" y="570"> <parameter key="attribute_filter_type" value="no_missing_values"/> </operator> <operator activated="true" class="multiply" compatibility="5.3.013" expanded="true" height="94" name="Filtered Dataset" width="90" x="715" y="570"/> <operator activated="true" class="join" compatibility="5.3.013" expanded="true" height="76" name="Join (3)" width="90" x="849" y="660"> <parameter key="join_type" value="left"/> <list key="key_attributes"/>
</operator> <connect from_op="PTA LOG" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="DAQ LOG" from_port="output" to_op="Generate Concatenation" to_port="example set input"/> <connect from_op="Generate Concatenation" from_port="example set output" to_op="Nominal to Text" to_port="example set input"/> <connect from_op="Nominal to Text" from_port="example set output" to_op="Select Attributes (2)" to_port="example set input"/> <connect from_op="Select Attributes (2)" from_port="example set output" to_op="Set Role (2)" to_port="example set input"/> <connect from_op="Set Role (2)" from_port="example set output" to_op="Join" to_port="right"/> <connect from_op="Join" from_port="join" to_op="Multiply (5)" to_port="input"/> <connect from_op="WEATHER LOG" from_port="output" to_op="Set Role (3)" to_port="example set input"/> <connect from_op="Set Role (3)" from_port="example set output" to_op="Join (2)" to_port="right"/> <connect from_op="Multiply (5)" from_port="output 1" to_op="Join (2)" to_port="left"/> <connect from_op="Join (2)" from_port="join" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_op="Rename by Replacing (2)" to_port="example set input"/> <connect from_op="Rename by Replacing (2)" from_port="example set output" to_op="Set Role (5)" to_port="example set input"/> <connect from_op="Set Role (5)" from_port="example set output" to_op="Generate ID (2)" to_port="example set input"/> <connect from_op="Generate ID (2)" from_port="example set output" to_op="Multiply (6)" to_port="input"/> <connect from_op="Multiply (6)" from_port="output 1" to_op="Declare Missing Value" to_port="example set input"/> <connect from_op="Multiply (6)" from_port="output 2" to_op="Select Attributes (4)" to_port="example set input"/> <connect from_op="Select Attributes (4)" from_port="example set output" to_op="Replace Missing Values (2)" to_port="example set input"/> <connect from_op="Replace Missing Values (2)" from_port="example set output" to_op="Generate Attributes (2)" to_port="example set input"/> <connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Select Attributes (5)" to_port="example set input"/> <connect from_op="Select Attributes (5)" from_port="example set output" to_op="Join (3)" to_port="right"/> <connect from_op="Declare Missing Value" from_port="example set output" to_op="Filter Examples (2)" to_port="example set input"/> <connect from_op="Filter Examples (2)" from_port="example set output" to_op="Select Attributes (3)" to_port="example set input"/> <connect from_op="Select Attributes (3)" from_port="example set output" to_op="Filtered Dataset" to_port="input"/> <connect from_op="Filtered Dataset" from_port="output 1" to_port="result 1"/> <connect from_op="Filtered Dataset" from_port="output 2" to_op="Join (3)" to_port="left"/> <connect from_op="Join (3)" from_port="join" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
