<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="5.3.008" expanded="true" height="60" name="Retrieve Iris" width="90" x="45" y="75"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="agglomerative_clustering" compatibility="5.3.008" expanded="true" height="76" name="Clustering" width="90" x="45" y="165"/> <operator activated="true" class="flatten_clustering" compatibility="5.3.008" expanded="true" height="76" name="Flatten Clustering" width="90" x="179" y="165"/> <operator activated="true" class="aggregate" compatibility="5.3.008" expanded="true" height="76" name="Aggregate" width="90" x="313" y="165"> <list key="aggregation_attributes"> <parameter key="a1" value="average"/> <parameter key="a2" value="average"/> <parameter key="a3" value="average"/> <parameter key="a4" value="average"/> </list> <parameter key="group_by_attributes" value="|cluster"/> </operator> <connect from_op="Retrieve Iris" from_port="output" to_op="Clustering" to_port="example set"/> <connect from_op="Clustering" from_port="cluster model" to_op="Flatten Clustering" to_port="hierarchical"/> <connect from_op="Clustering" from_port="example set" to_op="Flatten Clustering" to_port="example set"/> <connect from_op="Flatten Clustering" from_port="example set" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
