Hello RM-Team,
I tried to iterate over the attributes with the "loop attributes"-operator, but the "select attributes"-operator seems not to work well within a loop
It only work's on the first cycle, thats why I think its not my fault. Could you tell me if this is a bug, and maybe when you will fix it?
<process version="5.3.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="generate_data" compatibility="5.3.008" expanded="true" height="60" name="Generate Data" width="90" x="179" y="30">
<parameter key="number_examples" value="10"/>
<operator activated="true" class="loop_attributes" compatibility="5.3.008" expanded="true" height="76" name="Loop Attributes" width="90" x="313" y="30">
<operator activated="true" breakpoints="after" class="select_attributes" compatibility="5.3.008" expanded="true" height="76" name="Select Attributes" width="90" x="112" y="30">
<parameter key="attribute" value="%{loop_attribute}"/>
<connect from_port="example set" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_port="example set"/>
<portSpacing port="sink_example set" spacing="0"/>
</process>
<connect from_op="Generate Data" from_port="output" to_op="Loop Attributes" to_port="example set"/>
<connect from_op="Loop Attributes" from_port="example set" to_port="result 1"/>
</process>
</process>
Put a breakpoint on the SAtt-operator and see the difference between the output at the first cycle and the other one's.
Best xDSticker
