<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.008"> <context> <input/> <output/> <macros> <macro> <key>DB_TABLE_NAME</key> <value>SAPPrediction</value> </macro> <macro> <key>FIELD_NAME_0</key> <value>ID</value> </macro> <macro> <key>ROLE_0</key> <value>id</value> </macro> <macro> <key>FIELD_NAME_1</key> <value/> </macro> <macro> <key>ROLE_1</key> <value/> </macro> <macro> <key>FIELD_NAME_2</key> <value/> </macro> <macro> <key>FIELD_NAME_3</key> <value/> </macro> <macro> <key>FIELD_NAME_4</key> <value/> </macro> <macro> <key>FIELD_NAME_5</key> <value/> </macro> <macro> <key>FIELD_NAME_6</key> <value/> </macro> <macro> <key>FIELD_NAME_7</key> <value/> </macro> <macro> <key>FIELD_NAME_8</key> <value/> </macro> <macro> <key>FIELD_NAME_9</key> <value/> </macro> <macro> <key>ROLE_2</key> <value/> </macro> <macro> <key>ROLE_3</key> <value/> </macro> <macro> <key>ROLE_4</key> <value/> </macro> <macro> <key>ROLE_5</key> <value/> </macro> <macro> <key>ROLE_6</key> <value/> </macro> <macro> <key>ROLE_7</key> <value/> </macro> <macro> <key>ROLE_8</key> <value/> </macro> <macro> <key>ROLE_9</key> <value/> </macro> </macros> </context> <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="read_database" compatibility="5.3.008" expanded="true" height="60" name="Read Database" width="90" x="246" y="435"> <parameter key="connection" value="Semanco01TempDB"/> <parameter key="define_query" value="table name"/> <parameter key="table_name" value="%{DB_TABLE_NAME}"/> <enumeration key="parameters"/> </operator> <operator activated="true" class="set_role" compatibility="5.3.008" expanded="true" height="76" name="Set Role (2)" width="90" x="447" y="435"> <parameter key="attribute_name" value="%{FIELD_NAME_0}"/> <parameter key="target_role" value="%{ROLE_0}"/> <list key="set_additional_roles"> <parameter key="%{FIELD_NAME_1}" value="%{ROLE_1}"/> <parameter key="%{FIELD_NAME_2}" value="%{ROLE_2}"/> <parameter key="%{FIELD_NAME_3}" value="%{ROLE_3}"/> <parameter key="%{FIELD_NAME_4}" value="%{ROLE_4}"/> <parameter key="%{FIELD_NAME_5}" value="%{ROLE_5}"/> <parameter key="%{FIELD_NAME_6}" value="%{ROLE_6}"/> <parameter key="%{FIELD_NAME_7}" value="%{ROLE_7}"/> <parameter key="%{FIELD_NAME_8}" value="%{ROLE_8}"/> <parameter key="%{FIELD_NAME_9}" value="%{ROLE_9}"/> </list> </operator> <operator activated="true" class="retrieve" compatibility="5.3.008" expanded="true" height="60" name="Retrieve NewcastleAndMiddlesbrough" width="90" x="45" y="30"> <parameter key="repository_entry" value="../data/NewcastleAndMiddlesbrough"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.3.008" expanded="true" height="76" name="Select Attributes (2)" width="90" x="246" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="Adress|DraughtLobby|EstimatedSAP|GroudFloorHight|GroundFloorArea|NumberOfFloors|NumberOfRooms|NumberOfSidesSheltered|PassiveVents|Perimeter|PropertyAge|RoofArea|RoofTilt|TypeOfFloor|WallIsolation|WallType|WindowType|WindowsAndDoorsDraughtStripped|"/> </operator> <operator activated="true" class="rename" compatibility="5.3.008" expanded="true" height="76" name="Rename" width="90" x="447" y="30"> <parameter key="old_name" value="Adress"/> <parameter key="new_name" value="addressValue"/> <list key="rename_additional_attributes"> <parameter key="NumberOfFloors" value="number_Of_Complete_StoreysValue"/> <parameter key="NumberOfRooms" value="number_Of_RoomsValue"/> <parameter key="PropertyAge" value="Age_Class"/> <parameter key="GroundFloorArea" value="ground_Floor_AreaValue"/> <parameter key="GroudFloorHight" value="ground_Floor_HeightValue"/> <parameter key="Perimeter" value="building_PerimeterValue"/> <parameter key="PassiveVents" value="number_Of_Natural_Ventilation_DeviceValue"/> <parameter key="TypeOfFloor" value="Bottom_Floor_Type"/> <parameter key="DraughtLobby" value="Draught_Lobby"/> <parameter key="WindowsAndDoorsDraughtStripped" value="percentage_Of_Window_Door_Draught_StrippedValue"/> <parameter key="NumberOfSidesSheltered" value="number_Of_Sides_ShelteredValue"/> <parameter key="WallType" value="Type_Of_Wall"/> <parameter key="WindowType" value="window_TypeValue"/> <parameter key="RoofArea" value="Roof_Area"/> <parameter key="RoofTilt" value="Roof_Tilt"/> <parameter key="WallIsolation" value="Wall_Insulation_Type"/> </list> </operator> <operator activated="true" class="select_attributes" compatibility="5.3.008" expanded="true" height="76" name="Select Attributes (4)" width="90" x="648" y="435"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="window_TypeValue|percentage_Of_Window_Door_Draught_StrippedValue|number_Of_Sides_ShelteredValue|number_Of_RoomsValue|number_Of_Natural_Ventilation_DeviceValue|number_Of_Complete_StoreysValue|ground_Floor_HeightValue|ground_Floor_AreaValue|building_PerimeterValue|addressValue|Wall_Insulation_Type|Type_Of_Wall|Roof_Tilt|Roof_Area|Draught_Lobby|Building|Bottom_Floor_Type|Age_Class"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="generate_attributes" compatibility="5.3.008" expanded="true" height="76" name="Generate Attributes" width="90" x="849" y="435"> <list key="function_descriptions"> <parameter key="Age_Class" value="replace(Age_Class, "http://arcdev.housing.salle.url.edu/semanco/repository/sap/age_class/", "")"/> <parameter key="Bottom_Floor_Type" value="replace(Bottom_Floor_Type, "http://arcdev.housing.salle.url.edu/semanco/repository/sap/bottom_floor_type/", "")"/> <parameter key="Type_Of_Wall" value="replace(Type_Of_Wall, "http://arcdev.housing.salle.url.edu/semanco/repository/sap/type_of_wall/", "")"/> <parameter key="Wall_Insulation_Type" value="replace(Wall_Insulation_Type, "http://arcdev.housing.salle.url.edu/semanco/repository/sap/wall_insulation_type/", "")"/> <parameter key="Roof_Area" value="parse(replace(Roof_Area, "http://arcdev.housing.salle.url.edu/semanco/repository/sap/roof_area/", ""))"/> <parameter key="Roof_Tilt" value="parse(replace(Roof_Tilt, "http://arcdev.housing.salle.url.edu/semanco/repository/sap/roof_tilt/", ""))"/> <parameter key="Draught_Lobby" value="replace(Draught_Lobby, "http://arcdev.housing.salle.url.edu/semanco/repository/sap/draught_lobby/", "")"/> </list> </operator> <operator activated="true" class="set_role" compatibility="5.3.008" expanded="true" height="76" name="Set Role" width="90" x="1050" y="435"> <parameter key="attribute_name" value="addressValue"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="real_to_integer" compatibility="5.3.008" expanded="true" height="76" name="Real to Integer" width="90" x="1251" y="435"> <parameter key="attribute_filter_type" value="value_type"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="text_to_nominal" compatibility="5.3.008" expanded="true" height="76" name="Text to Nominal" width="90" x="1452" y="435"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="window_TypeValue||Draught_Lobby"/> </operator> <operator activated="true" class="multiply" compatibility="5.3.008" expanded="true" height="94" name="Multiply (2)" width="90" x="1653" y="435"/> <operator activated="true" class="generate_attributes" compatibility="5.3.008" expanded="true" height="76" name="Generate Attributes (2)" width="90" x="648" y="30"> <list key="function_descriptions"> <parameter key="Bottom_Floor_Type" value="replaceAll(Bottom_Floor_Type, " ", "_")"/> <parameter key="Type_Of_Wall" value="replaceAll(Type_Of_Wall, " ", "_")"/> <parameter key="Wall_Insulation_Type" value="replaceAll(Wall_Insulation_Type, " ", "_")"/> <parameter key="Type_Of_Wall" value="replaceAll(Type_Of_Wall, "Solid_Brick_with_internal", "Solid_Brick_with_internal_or_external_insulation")"/> <parameter key="Type_Of_Wall" value="replaceAll(Type_Of_Wall, "Cavity_with_internal_or_e", "Cavity_with_internal_or_external_insulation")"/> <parameter key="Wall_Insulation_Type" value="replaceAll(Wall_Insulation_Type, "Stone/Solid_Brick_with_50_mm_e", "Stone%2FSolid_Brick_with_50_mm_external_or_Internal_Insulation")"/> <parameter key="Wall_Insulation_Type" value="replaceAll(Wall_Insulation_Type, "StonelithiumGranite_or_Whinestone_a", "Stone%3A_Granite_or_Whinestone_as_Built")"/> <parameter key="Wall_Insulation_Type" value="replaceAll(Wall_Insulation_Type, "Filled_Cavity_with_50_mm_exter", "Filled_Cavity_with_50_mm_external_or_internal_insulation")"/> </list> </operator> <operator activated="true" class="nominal_to_text" compatibility="5.3.008" expanded="true" height="76" name="Nominal to Text" width="90" x="849" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="addressValue"/> </operator> <operator activated="true" class="set_role" compatibility="5.3.008" expanded="true" height="76" name="Set Role (3)" width="90" x="1050" y="30"> <parameter key="attribute_name" value="EstimatedSAP"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"> <parameter key="addressValue" value="id"/> </list> </operator> <operator activated="true" class="multiply" compatibility="5.3.008" expanded="true" height="94" name="Multiply" width="90" x="1251" y="30"/> <operator activated="true" class="nominal_to_numerical" compatibility="5.3.008" expanded="true" height="94" name="Nominal to Numerical (2)" width="90" x="1452" y="165"> <list key="comparison_groups"/> <parameter key="use_underscore_in_name" value="true"/> </operator> <operator activated="true" class="weight_by_correlation" compatibility="5.3.008" expanded="true" height="76" name="Weight by Correlation (2)" width="90" x="1653" y="165"/> <operator activated="true" class="select_attributes" compatibility="5.3.008" expanded="true" height="76" name="Select Attributes (3)" width="90" x="1854" y="300"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="addressValue|Age_Class|Bottom_Floor_Type|Draught_Lobby|Roof_Area|Roof_Tilt|Type_Of_Wall|Wall_Insulation_Type|building_PerimeterValue|ground_Floor_AreaValue|ground_Floor_HeightValue|number_Of_Complete_StoreysValue|number_Of_Natural_Ventilation_DeviceValue|number_Of_RoomsValue|number_Of_Sides_ShelteredValue|percentage_Of_Window_Door_Draught_StrippedValue|window_TypeValue"/> </operator> <operator activated="true" class="select_by_weights" compatibility="5.3.008" expanded="true" height="94" name="Select by Weights (2)" width="90" x="1854" y="165"> <parameter key="weight" value="0.5"/> </operator> <operator activated="true" class="nominal_to_numerical" compatibility="5.3.008" expanded="true" height="94" name="Nominal to Numerical" width="90" x="2055" y="300"> <parameter key="attributes" value="Age_Class|Bottom_Floor_Type|Draught_Lobby|Roof_Area|Roof_Tilt|Type_Of_Wall|Wall_Insulation_Type|window_TypeValue|addressValue"/> <list key="comparison_groups"/> <parameter key="use_underscore_in_name" value="true"/> </operator> <operator activated="true" class="neural_net" compatibility="5.3.008" expanded="true" height="76" name="NeuralNet(Correlation)" width="90" x="2055" y="165"> <list key="hidden_layers"/> <parameter key="training_cycles" value="12"/> <parameter key="learning_rate" value="0.6"/> <parameter key="decay" value="true"/> </operator> <operator activated="true" class="apply_model" compatibility="5.3.008" expanded="true" height="76" name="ApplyModel(Correliert)" width="90" x="2256" y="165"> <list key="application_parameters"/> </operator> <operator activated="true" breakpoints="before" class="rename" compatibility="5.3.008" expanded="true" height="76" name="Rename (2)" width="90" x="2457" y="165"> <parameter key="old_name" value="prediction(EstimatedSAP)"/> <parameter key="new_name" value="PredictionSAP"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="join" compatibility="5.3.008" expanded="true" height="76" name="Join (2)" width="90" x="2658" y="300"> <list key="key_attributes"/> </operator> <operator activated="true" class="join" compatibility="5.3.008" expanded="true" height="76" name="Join" width="90" x="2859" y="30"> <list key="key_attributes"> <parameter key="addressValue" value="addressValue"/> </list> </operator> <operator activated="true" class="select_attributes" compatibility="5.3.008" expanded="true" height="76" name="Select Attributes" width="90" x="3060" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="EstimatedSAP|PredictionSAP|addressValue||Building"/> </operator> <connect from_op="Read Database" from_port="output" to_op="Set Role (2)" to_port="example set input"/> <connect from_op="Set Role (2)" from_port="example set output" to_op="Select Attributes (4)" to_port="example set input"/> <connect from_op="Retrieve NewcastleAndMiddlesbrough" from_port="output" to_op="Select Attributes (2)" to_port="example set input"/> <connect from_op="Select Attributes (2)" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Generate Attributes (2)" to_port="example set input"/> <connect from_op="Select Attributes (4)" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Real to Integer" to_port="example set input"/> <connect from_op="Real to Integer" from_port="example set output" to_op="Text to Nominal" to_port="example set input"/> <connect from_op="Text to Nominal" from_port="example set output" to_op="Multiply (2)" to_port="input"/> <connect from_op="Multiply (2)" from_port="output 1" to_op="Select Attributes (3)" to_port="example set input"/> <connect from_op="Multiply (2)" from_port="output 2" to_op="Join (2)" to_port="right"/> <connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Nominal to Text" to_port="example set input"/> <connect from_op="Nominal to Text" from_port="example set output" to_op="Set Role (3)" to_port="example set input"/> <connect from_op="Set Role (3)" from_port="example set output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Join" to_port="left"/> <connect from_op="Multiply" from_port="output 2" to_op="Nominal to Numerical (2)" to_port="example set input"/> <connect from_op="Nominal to Numerical (2)" from_port="example set output" to_op="Weight by Correlation (2)" to_port="example set"/> <connect from_op="Weight by Correlation (2)" from_port="weights" to_op="Select by Weights (2)" to_port="weights"/> <connect from_op="Weight by Correlation (2)" from_port="example set" to_op="Select by Weights (2)" to_port="example set input"/> <connect from_op="Select Attributes (3)" from_port="example set output" to_op="Nominal to Numerical" to_port="example set input"/> <connect from_op="Select by Weights (2)" from_port="example set output" to_op="NeuralNet(Correlation)" to_port="training set"/> <connect from_op="Nominal to Numerical" from_port="example set output" to_op="ApplyModel(Correliert)" to_port="unlabelled data"/> <connect from_op="NeuralNet(Correlation)" from_port="model" to_op="ApplyModel(Correliert)" to_port="model"/> <connect from_op="ApplyModel(Correliert)" from_port="labelled data" to_op="Rename (2)" to_port="example set input"/> <connect from_op="Rename (2)" from_port="example set output" to_op="Join (2)" to_port="left"/> <connect from_op="Join (2)" from_port="join" to_op="Join" to_port="right"/> <connect from_op="Join" from_port="join" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>[ /code]
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.008"> <context> <input/> <output/> <macros> <macro> <key>DB_TABLE_NAME</key> <value>SAPPrediction</value> </macro> <macro> <key>FIELD_NAME_0</key> <value>ID</value> </macro> <macro> <key>ROLE_0</key> <value>id</value> </macro> <macro> <key>FIELD_NAME_1</key> <value/> </macro> <macro> <key>ROLE_1</key> <value/> </macro> <macro> <key>FIELD_NAME_2</key> <value/> </macro> <macro> <key>FIELD_NAME_3</key> <value/> </macro> <macro> <key>FIELD_NAME_4</key> <value/> </macro> <macro> <key>FIELD_NAME_5</key> <value/> </macro> <macro> <key>FIELD_NAME_6</key> <value/> </macro> <macro> <key>FIELD_NAME_7</key> <value/> </macro> <macro> <key>FIELD_NAME_8</key> <value/> </macro> <macro> <key>FIELD_NAME_9</key> <value/> </macro> <macro> <key>ROLE_2</key> <value/> </macro> <macro> <key>ROLE_3</key> <value/> </macro> <macro> <key>ROLE_4</key> <value/> </macro> <macro> <key>ROLE_5</key> <value/> </macro> <macro> <key>ROLE_6</key> <value/> </macro> <macro> <key>ROLE_7</key> <value/> </macro> <macro> <key>ROLE_8</key> <value/> </macro> <macro> <key>ROLE_9</key> <value/> </macro> </macros> </context> <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="5.3.008" expanded="true" height="60" name="Retrieve NewcastleAndMiddlesbrough" width="90" x="45" y="30"> <parameter key="repository_entry" value="./NewcastleAndMiddlesbrough"/> </operator> <operator activated="true" class="retrieve" compatibility="5.3.008" expanded="true" height="60" name="Retrieve (2)" width="90" x="246" y="435"> <parameter key="repository_entry" value="./rdforiginal"/> </operator> <operator activated="true" class="set_role" compatibility="5.3.008" expanded="true" height="76" name="Set Role (2)" width="90" x="447" y="435"> <parameter key="attribute_name" value="%{FIELD_NAME_0}"/> <parameter key="target_role" value="%{ROLE_0}"/> <list key="set_additional_roles"> <parameter key="%{FIELD_NAME_1}" value="%{ROLE_1}"/> <parameter key="%{FIELD_NAME_2}" value="%{ROLE_2}"/> <parameter key="%{FIELD_NAME_3}" value="%{ROLE_3}"/> <parameter key="%{FIELD_NAME_4}" value="%{ROLE_4}"/> <parameter key="%{FIELD_NAME_5}" value="%{ROLE_5}"/> <parameter key="%{FIELD_NAME_6}" value="%{ROLE_6}"/> <parameter key="%{FIELD_NAME_7}" value="%{ROLE_7}"/> <parameter key="%{FIELD_NAME_8}" value="%{ROLE_8}"/> <parameter key="%{FIELD_NAME_9}" value="%{ROLE_9}"/> </list> </operator> <operator activated="true" class="select_attributes" compatibility="5.3.008" expanded="true" height="76" name="Select Attributes (2)" width="90" x="246" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="Adress|DraughtLobby|EstimatedSAP|GroudFloorHight|GroundFloorArea|NumberOfFloors|NumberOfRooms|NumberOfSidesSheltered|PassiveVents|Perimeter|PropertyAge|RoofArea|RoofTilt|TypeOfFloor|WallIsolation|WallType|WindowType|WindowsAndDoorsDraughtStripped|"/> </operator> <operator activated="true" class="rename" compatibility="5.3.008" expanded="true" height="76" name="Rename" width="90" x="447" y="30"> <parameter key="old_name" value="Adress"/> <parameter key="new_name" value="addressValue"/> <list key="rename_additional_attributes"> <parameter key="NumberOfFloors" value="number_Of_Complete_StoreysValue"/> <parameter key="NumberOfRooms" value="number_Of_RoomsValue"/> <parameter key="PropertyAge" value="Age_Class"/> <parameter key="GroundFloorArea" value="ground_Floor_AreaValue"/> <parameter key="GroudFloorHight" value="ground_Floor_HeightValue"/> <parameter key="Perimeter" value="building_PerimeterValue"/> <parameter key="PassiveVents" value="number_Of_Natural_Ventilation_DeviceValue"/> <parameter key="TypeOfFloor" value="Bottom_Floor_Type"/> <parameter key="DraughtLobby" value="Draught_Lobby"/> <parameter key="WindowsAndDoorsDraughtStripped" value="percentage_Of_Window_Door_Draught_StrippedValue"/> <parameter key="NumberOfSidesSheltered" value="number_Of_Sides_ShelteredValue"/> <parameter key="WallType" value="Type_Of_Wall"/> <parameter key="WindowType" value="window_TypeValue"/> <parameter key="RoofArea" value="Roof_Area"/> <parameter key="RoofTilt" value="Roof_Tilt"/> <parameter key="WallIsolation" value="Wall_Insulation_Type"/> </list> </operator> <operator activated="true" class="select_attributes" compatibility="5.3.008" expanded="true" height="76" name="Select Attributes (4)" width="90" x="648" y="435"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="window_TypeValue|percentage_Of_Window_Door_Draught_StrippedValue|number_Of_Sides_ShelteredValue|number_Of_RoomsValue|number_Of_Natural_Ventilation_DeviceValue|number_Of_Complete_StoreysValue|ground_Floor_HeightValue|ground_Floor_AreaValue|building_PerimeterValue|addressValue|Wall_Insulation_Type|Type_Of_Wall|Roof_Tilt|Roof_Area|Draught_Lobby|Building|Bottom_Floor_Type|Age_Class"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="generate_attributes" compatibility="5.3.008" expanded="true" height="76" name="Generate Attributes" width="90" x="849" y="435"> <list key="function_descriptions"> <parameter key="Age_Class" value="replace(Age_Class, "http://arcdev.housing.salle.url.edu/semanco/repository/sap/age_class/", "")"/> <parameter key="Bottom_Floor_Type" value="replace(Bottom_Floor_Type, "http://arcdev.housing.salle.url.edu/semanco/repository/sap/bottom_floor_type/", "")"/> <parameter key="Type_Of_Wall" value="replace(Type_Of_Wall, "http://arcdev.housing.salle.url.edu/semanco/repository/sap/type_of_wall/", "")"/> <parameter key="Wall_Insulation_Type" value="replace(Wall_Insulation_Type, "http://arcdev.housing.salle.url.edu/semanco/repository/sap/wall_insulation_type/", "")"/> <parameter key="Roof_Area" value="parse(replace(Roof_Area, "http://arcdev.housing.salle.url.edu/semanco/repository/sap/roof_area/", ""))"/> <parameter key="Roof_Tilt" value="parse(replace(Roof_Tilt, "http://arcdev.housing.salle.url.edu/semanco/repository/sap/roof_tilt/", ""))"/> <parameter key="Draught_Lobby" value="replace(Draught_Lobby, "http://arcdev.housing.salle.url.edu/semanco/repository/sap/draught_lobby/", "")"/> <parameter key="EstimatedSAP" value="parse("1")"/> </list> </operator> <operator activated="true" class="set_role" compatibility="5.3.008" expanded="true" height="76" name="Set Role" width="90" x="1050" y="435"> <parameter key="attribute_name" value="addressValue"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"> <parameter key="EstimatedSAP" value="label"/> </list> </operator> <operator activated="true" class="real_to_integer" compatibility="5.3.008" expanded="true" height="76" name="Real to Integer" width="90" x="1251" y="435"> <parameter key="attribute_filter_type" value="value_type"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="text_to_nominal" compatibility="5.3.008" expanded="true" height="76" name="Text to Nominal" width="90" x="1452" y="435"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="window_TypeValue||Draught_Lobby"/> </operator> <operator activated="true" class="multiply" compatibility="5.3.008" expanded="true" height="76" name="Multiply (2)" width="90" x="1653" y="435"/> <operator activated="true" class="generate_attributes" compatibility="5.3.008" expanded="true" height="76" name="Generate Attributes (2)" width="90" x="648" y="30"> <list key="function_descriptions"> <parameter key="Bottom_Floor_Type" value="replaceAll(Bottom_Floor_Type, " ", "_")"/> <parameter key="Type_Of_Wall" value="replaceAll(Type_Of_Wall, " ", "_")"/> <parameter key="Wall_Insulation_Type" value="replaceAll(Wall_Insulation_Type, " ", "_")"/> <parameter key="Type_Of_Wall" value="replaceAll(Type_Of_Wall, "Solid_Brick_with_internal", "Solid_Brick_with_internal_or_external_insulation")"/> <parameter key="Type_Of_Wall" value="replaceAll(Type_Of_Wall, "Cavity_with_internal_or_e", "Cavity_with_internal_or_external_insulation")"/> <parameter key="Wall_Insulation_Type" value="replaceAll(Wall_Insulation_Type, "Stone/Solid_Brick_with_50_mm_e", "Stone%2FSolid_Brick_with_50_mm_external_or_Internal_Insulation")"/> <parameter key="Wall_Insulation_Type" value="replaceAll(Wall_Insulation_Type, "StonelithiumGranite_or_Whinestone_a", "Stone%3A_Granite_or_Whinestone_as_Built")"/> <parameter key="Wall_Insulation_Type" value="replaceAll(Wall_Insulation_Type, "Filled_Cavity_with_50_mm_exter", "Filled_Cavity_with_50_mm_external_or_internal_insulation")"/> </list> </operator> <operator activated="true" class="nominal_to_text" compatibility="5.3.008" expanded="true" height="76" name="Nominal to Text" width="90" x="849" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="addressValue"/> </operator> <operator activated="true" class="set_role" compatibility="5.3.008" expanded="true" height="76" name="Set Role (3)" width="90" x="1050" y="30"> <parameter key="attribute_name" value="EstimatedSAP"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"> <parameter key="addressValue" value="id"/> </list> </operator> <operator activated="true" class="multiply" compatibility="5.3.008" expanded="true" height="76" name="Multiply" width="90" x="1251" y="30"/> <operator activated="true" class="nominal_to_numerical" compatibility="5.3.008" expanded="true" height="94" name="Nominal to Numerical (2)" width="90" x="1452" y="165"> <list key="comparison_groups"/> <parameter key="use_underscore_in_name" value="true"/> </operator> <operator activated="true" class="multiply" compatibility="5.3.008" expanded="true" height="94" name="Multiply (3)" width="90" x="1519" y="300"/> <operator activated="true" class="store" compatibility="5.3.008" expanded="true" height="60" name="Store" width="90" x="1653" y="300"> <parameter key="repository_entry" value="./original"/> </operator> <operator activated="true" class="weight_by_correlation" compatibility="5.3.008" expanded="true" height="76" name="Weight by Correlation (2)" width="90" x="1653" y="165"/> <operator activated="true" class="select_attributes" compatibility="5.3.008" expanded="true" height="76" name="Select Attributes (3)" width="90" x="1854" y="300"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="addressValue|Age_Class|Bottom_Floor_Type|Draught_Lobby|Roof_Area|Roof_Tilt|Type_Of_Wall|Wall_Insulation_Type|building_PerimeterValue|ground_Floor_AreaValue|ground_Floor_HeightValue|number_Of_Complete_StoreysValue|number_Of_Natural_Ventilation_DeviceValue|number_Of_RoomsValue|number_Of_Sides_ShelteredValue|percentage_Of_Window_Door_Draught_StrippedValue|window_TypeValue"/> </operator> <operator activated="true" class="select_by_weights" compatibility="5.3.008" expanded="true" height="94" name="Select by Weights (2)" width="90" x="1854" y="165"> <parameter key="weight" value="0.5"/> </operator> <operator activated="true" class="nominal_to_numerical" compatibility="5.3.008" expanded="true" height="94" name="Nominal to Numerical" width="90" x="2055" y="300"> <parameter key="attributes" value="Age_Class|Bottom_Floor_Type|Draught_Lobby|Roof_Area|Roof_Tilt|Type_Of_Wall|Wall_Insulation_Type|window_TypeValue|addressValue"/> <list key="comparison_groups"/> <parameter key="use_underscore_in_name" value="true"/> </operator> <operator activated="true" class="multiply" compatibility="5.3.008" expanded="true" height="76" name="Multiply (5)" width="90" x="2189" y="525"/> <operator activated="true" class="data_to_weights" compatibility="5.3.008" expanded="true" height="76" name="Data to Weights" width="90" x="1988" y="210"/> <operator activated="true" class="order_attributes" compatibility="5.3.008" expanded="true" height="76" name="Reorder Attributes (2)" width="90" x="2189" y="165"> <parameter key="sort_mode" value="alphabetically"/> </operator> <operator activated="true" class="store" compatibility="5.3.008" expanded="true" height="60" name="Store (4)" width="90" x="2256" y="75"> <parameter key="repository_entry" value="train data"/> </operator> <operator activated="true" class="retrieve" compatibility="5.3.008" expanded="true" height="60" name="Retrieve" width="90" x="2457" y="525"> <parameter key="repository_entry" value="./rdfdata"/> </operator> <operator activated="true" breakpoints="after" class="select_by_weights" compatibility="5.3.008" expanded="true" height="94" name="Select by Weights" width="90" x="2524" y="390"/> <operator activated="true" class="order_attributes" compatibility="5.3.008" expanded="true" height="76" name="Reorder Attributes" width="90" x="2658" y="390"> <parameter key="sort_mode" value="alphabetically"/> </operator> <operator activated="true" class="store" compatibility="5.3.008" expanded="true" height="60" name="Store (2)" width="90" x="2323" y="525"> <parameter key="repository_entry" value="./rdfdata"/> </operator> <operator activated="true" class="retrieve" compatibility="5.3.008" expanded="true" height="60" name="Retrieve (4)" width="90" x="2256" y="255"> <parameter key="repository_entry" value="train data"/> </operator> <operator activated="true" class="neural_net" compatibility="5.3.008" expanded="true" height="76" name="NeuralNet(Correlation)" width="90" x="2390" y="165"> <list key="hidden_layers"/> <parameter key="training_cycles" value="12"/> <parameter key="learning_rate" value="0.6"/> <parameter key="decay" value="true"/> </operator>
<operator activated="true" class="apply_model" compatibility="5.3.008" expanded="true" height="76" name="ApplyModel(Correliert)" width="90" x="2524" y="165"> <list key="application_parameters"/> </operator> <connect from_op="Retrieve NewcastleAndMiddlesbrough" from_port="output" to_op="Select Attributes (2)" to_port="example set input"/> <connect from_op="Retrieve (2)" from_port="output" to_op="Set Role (2)" to_port="example set input"/> <connect from_op="Set Role (2)" from_port="example set output" to_op="Select Attributes (4)" to_port="example set input"/> <connect from_op="Select Attributes (2)" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Generate Attributes (2)" to_port="example set input"/> <connect from_op="Select Attributes (4)" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Real to Integer" to_port="example set input"/> <connect from_op="Real to Integer" from_port="example set output" to_op="Text to Nominal" to_port="example set input"/> <connect from_op="Text to Nominal" from_port="example set output" to_op="Multiply (2)" to_port="input"/> <connect from_op="Multiply (2)" from_port="output 1" to_op="Select Attributes (3)" to_port="example set input"/> <connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Nominal to Text" to_port="example set input"/> <connect from_op="Nominal to Text" from_port="example set output" to_op="Set Role (3)" to_port="example set input"/> <connect from_op="Set Role (3)" from_port="example set output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Nominal to Numerical (2)" to_port="example set input"/> <connect from_op="Nominal to Numerical (2)" from_port="example set output" to_op="Multiply (3)" to_port="input"/> <connect from_op="Multiply (3)" from_port="output 1" to_op="Weight by Correlation (2)" to_port="example set"/> <connect from_op="Multiply (3)" from_port="output 2" to_op="Store" to_port="input"/> <connect from_op="Weight by Correlation (2)" from_port="weights" to_op="Select by Weights (2)" to_port="weights"/> <connect from_op="Weight by Correlation (2)" from_port="example set" to_op="Select by Weights (2)" to_port="example set input"/> <connect from_op="Select Attributes (3)" from_port="example set output" to_op="Nominal to Numerical" to_port="example set input"/> <connect from_op="Select by Weights (2)" from_port="example set output" to_op="Data to Weights" to_port="example set"/> <connect from_op="Nominal to Numerical" from_port="example set output" to_op="Multiply (5)" to_port="input"/> <connect from_op="Multiply (5)" from_port="output 1" to_op="Store (2)" to_port="input"/> <connect from_op="Data to Weights" from_port="weights" to_op="Select by Weights" to_port="weights"/> <connect from_op="Data to Weights" from_port="example set" to_op="Reorder Attributes (2)" to_port="example set input"/> <connect from_op="Reorder Attributes (2)" from_port="example set output" to_op="Store (4)" to_port="input"/> <connect from_op="Retrieve" from_port="output" to_op="Select by Weights" to_port="example set input"/> <connect from_op="Select by Weights" from_port="example set output" to_op="Reorder Attributes" to_port="example set input"/> <connect from_op="Reorder Attributes" from_port="example set output" to_op="ApplyModel(Correliert)" to_port="unlabelled data"/> <connect from_op="Retrieve (4)" from_port="output" to_op="NeuralNet(Correlation)" to_port="training set"/> <connect from_op="NeuralNet(Correlation)" from_port="model" to_op="ApplyModel(Correliert)" to_port="model"/> <connect from_op="ApplyModel(Correliert)" from_port="labelled data" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
