<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process"> <parameter key="parallelize_main_process" value="true"/> <process expanded="true"> <operator activated="true" class="text:process_document_from_file" compatibility="5.3.000" expanded="true" height="76" name="Process Documents from Files (3)" width="90" x="45" y="75"> <list key="text_directories"> <parameter key="C11" value="C:\Users\Ramy\Desktop\RCVLEV2\C11"/> <parameter key="C12" value="C:\Users\Ramy\Desktop\RCVLEV2\C12"/> <parameter key="C13" value="C:\Users\Ramy\Desktop\RCVLEV2\C13"/> <parameter key="C14" value="C:\Users\Ramy\Desktop\RCVLEV2\C14"/> <parameter key="C16" value="C:\Users\Ramy\Desktop\RCVLEV2\C16"/> <parameter key="C17" value="C:\Users\Ramy\Desktop\RCVLEV2\C17"/> <parameter key="C21" value="C:\Users\Ramy\Desktop\RCVLEV2\C21"/> <parameter key="C22" value="C:\Users\Ramy\Desktop\RCVLEV2\C22"/> <parameter key="C23" value="C:\Users\Ramy\Desktop\RCVLEV2\C23"/> <parameter key="C24" value="C:\Users\Ramy\Desktop\RCVLEV2\C24"/> <parameter key="C32" value="C:\Users\Ramy\Desktop\RCVLEV2\C32"/> <parameter key="C33" value="C:\Users\Ramy\Desktop\RCVLEV2\C33"/> <parameter key="C34" value="C:\Users\Ramy\Desktop\RCVLEV2\C34"/> <parameter key="C42" value="C:\Users\Ramy\Desktop\RCVLEV2\C42"/> <parameter key="E11" value="C:\Users\Ramy\Desktop\RCVLEV2\E11"/> <parameter key="E61" value="C:\Users\Ramy\Desktop\RCVLEV2\E61"/> <parameter key="E71" value="C:\Users\Ramy\Desktop\RCVLEV2\E71"/> <parameter key="C15" value="C:\Users\Ramy\Desktop\RCVLEV2\F_C15"/> <parameter key="C17" value="C:\Users\Ramy\Desktop\RCVLEV2\F_C17"/> <parameter key="C18" value="C:\Users\Ramy\Desktop\RCVLEV2\F_C18"/> <parameter key="C31" value="C:\Users\Ramy\Desktop\RCVLEV2\F_C31"/> <parameter key="C33" value="C:\Users\Ramy\Desktop\RCVLEV2\F_C33"/> <parameter key="C41" value="C:\Users\Ramy\Desktop\RCVLEV2\F_C41"/> <parameter key="E12" value="C:\Users\Ramy\Desktop\RCVLEV2\F_E12"/> <parameter key="E13" value="C:\Users\Ramy\Desktop\RCVLEV2\F_E13"/> <parameter key="E14" value="C:\Users\Ramy\Desktop\RCVLEV2\F_E14"/> <parameter key="E21" value="C:\Users\Ramy\Desktop\RCVLEV2\F_E21"/> <parameter key="E31" value="C:\Users\Ramy\Desktop\RCVLEV2\F_E31"/> <parameter key="E41" value="C:\Users\Ramy\Desktop\RCVLEV2\F_E41"/> <parameter key="E51" value="C:\Users\Ramy\Desktop\RCVLEV2\F_E51"/> <parameter key="G15" value="C:\Users\Ramy\Desktop\RCVLEV2\F_G15"/> <parameter key="M13" value="C:\Users\Ramy\Desktop\RCVLEV2\F_M13"/> <parameter key="M14" value="C:\Users\Ramy\Desktop\RCVLEV2\F_M14"/> <parameter key="GCRIM" value="C:\Users\Ramy\Desktop\RCVLEV2\GCRIM"/> <parameter key="GDEF" value="C:\Users\Ramy\Desktop\RCVLEV2\GDEF"/> <parameter key="GDIP" value="C:\Users\Ramy\Desktop\RCVLEV2\GDIP"/> <parameter key="GDIS" value="C:\Users\Ramy\Desktop\RCVLEV2\GDIS"/> <parameter key="GENT" value="C:\Users\Ramy\Desktop\RCVLEV2\GENT"/> <parameter key="GENV" value="C:\Users\Ramy\Desktop\RCVLEV2\GENV"/> <parameter key="GFAS" value="C:\Users\Ramy\Desktop\RCVLEV2\GFAS"/> <parameter key="GHEA" value="C:\Users\Ramy\Desktop\RCVLEV2\GHEA"/> <parameter key="GJOB" value="C:\Users\Ramy\Desktop\RCVLEV2\GJOB"/> <parameter key="GODD" value="C:\Users\Ramy\Desktop\RCVLEV2\GODD"/> <parameter key="GPO" value="C:\Users\Ramy\Desktop\RCVLEV2\GPO"/> <parameter key="GPRO" value="C:\Users\Ramy\Desktop\RCVLEV2\GPRO"/> <parameter key="GREL" value="C:\Users\Ramy\Desktop\RCVLEV2\GREL"/> <parameter key="GSPO" value="C:\Users\Ramy\Desktop\RCVLEV2\GSPO"/> <parameter key="GTOUR" value="C:\Users\Ramy\Desktop\RCVLEV2\GTOUR"/> <parameter key="GVIO" value="C:\Users\Ramy\Desktop\RCVLEV2\GVIO"/> <parameter key="GVOTE" value="C:\Users\Ramy\Desktop\RCVLEV2\GVOTE"/> </list> <parameter key="vector_creation" value="Term Frequency"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="5.3.000" expanded="true" height="60" name="Tokenize (3)" width="90" x="45" y="30"/> <operator activated="true" class="text:transform_cases" compatibility="5.3.000" expanded="true" height="60" name="Transform Cases (3)" width="90" x="180" y="30"/> <operator activated="true" class="text:filter_stopwords_dictionary" compatibility="5.3.000" expanded="true" height="76" name="Filter Stopwords (3)" width="90" x="315" y="30"> <parameter key="file" value="C:\Users\Ramy\Desktop\stopwords.txt"/> </operator> <connect from_port="document" to_op="Tokenize (3)" to_port="document"/> <connect from_op="Tokenize (3)" from_port="document" to_op="Transform Cases (3)" to_port="document"/> <connect from_op="Transform Cases (3)" from_port="document" to_op="Filter Stopwords (3)" to_port="document"/> <connect from_op="Filter Stopwords (3)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <connect from_op="Process Documents from Files (3)" from_port="word list" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>\the error will show in the log window as follow "Error creating renderer: java.lang.ArrayIndexOutOfBoundsException: 48"Thanks and regards,Raa
