<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.008" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="45" y="75"> <list key="attribute_values"> <parameter key="abbreviations" value=""AA BB DD""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.008" expanded="true" height="60" name="Generate Data by User Specification (3)" width="90" x="45" y="165"> <list key="attribute_values"> <parameter key="abbreviations" value=""EE BB DD""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.008" expanded="true" height="60" name="Generate Data by User Specification (2)" width="90" x="45" y="255"> <list key="attribute_values"> <parameter key="abbreviations" value=""AA BB CC EE""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="append" compatibility="5.3.008" expanded="true" height="112" name="Append" width="90" x="246" y="75"/> <operator activated="true" class="split" compatibility="5.3.008" expanded="true" height="76" name="Split" width="90" x="380" y="75"> <parameter key="split_pattern" value=" "/> <parameter key="split_mode" value="unordered_split"/> </operator> <operator activated="true" class="rename_by_replacing" compatibility="5.3.008" expanded="true" height="76" name="Rename by Replacing" width="90" x="514" y="75"> <parameter key="replace_what" value=".*_(.*)"/> <parameter key="replace_by" value="$1"/> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Append" to_port="example set 1"/> <connect from_op="Generate Data by User Specification (3)" from_port="output" to_op="Append" to_port="example set 2"/> <connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Append" to_port="example set 3"/> <connect from_op="Append" from_port="merged set" to_op="Split" to_port="example set input"/> <connect from_op="Split" from_port="example set output" to_op="Rename by Replacing" to_port="example set input"/> <connect from_op="Rename by Replacing" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
