We got Error 14. After that, we tried to renumber those elements but it didn't work. What we can do? Can you help us? Thank you so much.
Your elements need to have a property assigned to them.
You can either assign them to the component where the elements are contained (indirect) or on the elements themselves (direct)
Your elements need to have a property assigned to them. You can either assign them to the component where the elements are contained (indirect) or on the elements themselves (direct)
Also verify the correct property type is assigned to the correct element type (ie PSHELL for 2d elements, PSOLID for 3d elements...)
