[SOLVED] Name conflict detection when renaming multiple attributes
User: "tennenrishin"
New Altair Community Member
Updated by Jocelyn
Is the following process supposed to throw an error? Prefixing all names with 'a' should not introduce any conflicts in the resulting name set, I would think.
<process version="5.3.005">
 <context>
   <input/>
   <output/>
   <macros/>
 </context>
 <operator activated="true" class="process" compatibility="5.3.005" expanded="true" name="Process">
   <process expanded="true">
     <operator activated="true" class="generate_data_user_specification" compatibility="5.3.005" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="112" y="75">
       <list key="attribute_values">
         <parameter key="a" value="1"/>
         <parameter key="aa" value="2"/>
       </list>
     <operator activated="true" class="rename_by_replacing" compatibility="5.3.005" expanded="true" height="76" name="Rename by Replacing" width="90" x="313" y="75">
       <parameter key="replace_what" value="^"/>
       <parameter key="replace_by" value="a"/>
     <connect from_op="Generate Data by User Specification" from_port="output" to_op="Rename by Replacing" to_port="example set input"/>
     <connect from_op="Rename by Replacing" from_port="example set output" to_port="result 1"/>
   </process>
</process>
1 - 2 of 21
    User: "Andrew2"
    I reckon you'd need (.*) as the search string and a$1 as the replacement. The $1 numbered group ensures the existing name is retained.
    Andrew
    User: "MariusHelf"
    I created an internal bug report requesting that duplicate attribute names are checked with respect to the final result set, not on intermediate results.
