I'm a Bachelor Student at the Technische Universität Darmstadt and I'm currently trying to use Rapidminer for my thesis.
I have a few questions/problems regarding the Plot View feature. I'm analyzing a CSV sheet of Poker stats which look like this:
id_player hands Win% BB/100 vpip (w/walks) vpip pfr pfr (simple) vpip/pfr adv
9236 1211 0,21 0,00 21,93 20,48 19,98 18,66 1,10
31364 1031 0,23 0,00 36,11 34,92 11,35 10,96 3,18
43431 9747 0,17 -0,01 23,50 22,85 16,31 15,85 1,44
318 12770 0,18 -0,01 19,68 18,61 15,49 14,64 1,27
11351 7901 0,23 -0,02 26,44 24,95 23,26 21,95 1,14
56886 19753 0,16 -0,02 22,24 21,71 17,37 16,95 1,28
This is just a small extract. I've imported the sheet into a local repository and everything looks fine in the Data View.
I have a few problems in Plot View though:
1. There is no "export image..." Button on the left side when I'm on the scatter graph for example.
2. There is no legend for color if I select a color column (and there is no legend when I select "none" in the color column either)
3. The axes in the Scatter 3D Plot are really weird. For example if I take
VPIP -> x-Axis
PFR -> y-Axis
BB/100 -> z-Axis
All axes are between 0 and 2000 - this makes no sense at all for me. All my values are usually between 0 and 100 with the exception of BB/100 where it's in [-infty;+infty].
I've tried to use the scales settings but it does not work (it simply moves around the points: up or down, left or right etc depending on how I set them.)
Can anyone help me here?
Kind Regards
