<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process"> <process expanded="true" height="741" width="1016"> <operator activated="true" class="text:process_document_from_file" compatibility="5.2.004" expanded="true" height="76" name="Process dataset" width="90" x="45" y="30"> <list key="text_directories"> <parameter key="1" value="/Users/kasper2304/Desktop/Msc. Marketing Thesis/Modeling/Trainingset/positive_cases"/> </list> <parameter key="prune_method" value="percentual"/> <parameter key="prunde_below_percent" value="1.0"/> <parameter key="prune_above_percent" value="99.0"/> <process expanded="true" height="759" width="765"> <operator activated="true" class="text:tokenize" compatibility="5.2.004" expanded="true" height="60" name="Tokenize" width="90" x="45" y="30"/> <operator activated="true" class="text:transform_cases" compatibility="5.2.004" expanded="true" height="60" name="Transform Cases" width="90" x="45" y="120"/> <operator activated="true" class="text:extract_token_number" compatibility="5.2.004" expanded="true" height="60" name="Extract Token Number" width="90" x="45" y="210"/> <operator activated="true" class="text:extract_length" compatibility="5.2.004" expanded="true" height="60" name="Extract Length" width="90" x="45" y="300"/> <operator activated="true" class="text:generate_n_grams_terms" compatibility="5.2.004" expanded="true" height="60" name="Generate n-Grams (Terms)" width="90" x="179" y="300"> <parameter key="max_length" value="3"/> </operator> <operator activated="true" class="text:filter_stopwords_english" compatibility="5.2.004" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="179" y="210"/> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/> <connect from_op="Transform Cases" from_port="document" to_op="Extract Token Number" to_port="document"/> <connect from_op="Extract Token Number" from_port="document" to_op="Extract Length" to_port="document"/> <connect from_op="Extract Length" from_port="document" to_op="Generate n-Grams (Terms)" to_port="document"/> <connect from_op="Generate n-Grams (Terms)" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/> <connect from_op="Filter Stopwords (English)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="filter_examples" compatibility="5.3.000" expanded="true" height="76" name="Filter .DS_Store" width="90" x="179" y="30"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="metadata_file = .DS_Store"/> <parameter key="invert_filter" value="true"/> </operator> <operator activated="true" class="text:process_document_from_file" compatibility="5.2.004" expanded="true" height="76" name="Process dataset (2)" width="90" x="45" y="120"> <list key="text_directories"> <parameter key="0" value="/Users/kasper2304/Desktop/Msc. Marketing Thesis/Modeling/Trainingset/negative_cases"/> </list> <parameter key="prune_method" value="percentual"/> <parameter key="prunde_below_percent" value="1.0"/> <parameter key="prune_above_percent" value="99.0"/> <process expanded="true" height="789" width="805"> <operator activated="true" class="text:tokenize" compatibility="5.2.004" expanded="true" height="60" name="Tokenize (2)" width="90" x="45" y="30"/> <operator activated="true" class="text:transform_cases" compatibility="5.2.004" expanded="true" height="60" name="Transform Cases (2)" width="90" x="45" y="120"/> <operator activated="true" class="text:extract_token_number" compatibility="5.2.004" expanded="true" height="60" name="Extract Token Number (2)" width="90" x="45" y="210"/> <operator activated="true" class="text:extract_length" compatibility="5.2.004" expanded="true" height="60" name="Extract Length (2)" width="90" x="45" y="300"/> <operator activated="true" class="text:generate_n_grams_terms" compatibility="5.2.004" expanded="true" height="60" name="Generate n-Grams (2)" width="90" x="179" y="300"> <parameter key="max_length" value="3"/> </operator> <operator activated="true" class="text:filter_stopwords_english" compatibility="5.2.004" expanded="true" height="60" name="Filter Stopwords (2)" width="90" x="179" y="210"/> <connect from_port="document" to_op="Tokenize (2)" to_port="document"/> <connect from_op="Tokenize (2)" from_port="document" to_op="Transform Cases (2)" to_port="document"/> <connect from_op="Transform Cases (2)" from_port="document" to_op="Extract Token Number (2)" to_port="document"/> <connect from_op="Extract Token Number (2)" from_port="document" to_op="Extract Length (2)" to_port="document"/> <connect from_op="Extract Length (2)" from_port="document" to_op="Generate n-Grams (2)" to_port="document"/> <connect from_op="Generate n-Grams (2)" from_port="document" to_op="Filter Stopwords (2)" to_port="document"/> <connect from_op="Filter Stopwords (2)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="filter_examples" compatibility="5.3.000" expanded="true" height="76" name="Filter .DS_Store (2)" width="90" x="179" y="120"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="metadata_file = .DS_Store"/> <parameter key="invert_filter" value="true"/> </operator> <operator activated="true" class="union" compatibility="5.3.000" expanded="true" height="76" name="Union (2)" width="90" x="313" y="75"/> <operator activated="true" class="replace_missing_values" compatibility="5.3.000" expanded="true" height="94" name="Replace Missing Values" width="90" x="447" y="75"> <parameter key="numeric_condition" value=""?""/> <parameter key="default" value="zero"/> <list key="columns"/> </operator> <operator activated="true" class="set_role" compatibility="5.3.000" expanded="true" height="76" name="Set Role" width="90" x="581" y="75"> <parameter key="name" value="label"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="store" compatibility="5.3.000" expanded="true" height="60" name="Store BoW" width="90" x="715" y="75"> <parameter key="repository_entry" value="Pre-processing/Misc/FullDataset_TEST"/> </operator> <connect from_op="Process dataset" from_port="example set" to_op="Filter .DS_Store" to_port="example set input"/> <connect from_op="Filter .DS_Store" from_port="example set output" to_op="Union (2)" to_port="example set 1"/> <connect from_op="Process dataset (2)" from_port="example set" to_op="Filter .DS_Store (2)" to_port="example set input"/> <connect from_op="Filter .DS_Store (2)" from_port="example set output" to_op="Union (2)" to_port="example set 2"/> <connect from_op="Union (2)" from_port="union" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Store BoW" to_port="input"/> <connect from_op="Store BoW" from_port="through" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.005"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.005" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="text:create_document" compatibility="5.3.000" expanded="true" height="60" name="Create Document" width="90" x="45" y="30"> <parameter key="text" value="the quick brown fox jumped over the lazy dog "/> <parameter key="add label" value="true"/> <parameter key="label_value" value="positive"/> </operator> <operator activated="true" class="text:create_document" compatibility="5.3.000" expanded="true" height="60" name="Create Document (2)" width="90" x="45" y="300"> <parameter key="text" value="the lazy dog was jumped over by the quick fox"/> <parameter key="add label" value="true"/> <parameter key="label_value" value="negative"/> </operator> <operator activated="true" class="text:process_documents" compatibility="5.3.000" expanded="true" height="94" name="Process Documents" width="90" x="45" y="120"> <parameter key="vector_creation" value="Term Occurrences"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="5.3.000" expanded="true" height="60" name="Tokenize (3)" width="90" x="179" y="120"/> <connect from_port="document" to_op="Tokenize (3)" to_port="document"/> <connect from_op="Tokenize (3)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="text:wordlist_to_data" compatibility="5.3.000" expanded="true" height="76" name="WordList to Data" width="90" x="179" y="30"/> <operator activated="true" class="select_attributes" compatibility="5.3.005" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="120"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|word"/> </operator> <operator activated="true" class="text:process_documents" compatibility="5.3.000" expanded="true" height="94" name="Process Documents (2)" width="90" x="45" y="390"> <parameter key="vector_creation" value="Term Occurrences"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="5.3.000" expanded="true" name="Tokenize (4)"/> <connect from_port="document" to_op="Tokenize (4)" to_port="document"/> <connect from_op="Tokenize (4)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="text:wordlist_to_data" compatibility="5.3.000" expanded="true" height="76" name="WordList to Data (2)" width="90" x="179" y="300"/> <operator activated="true" class="select_attributes" compatibility="5.3.005" expanded="true" height="76" name="Select Attributes (2)" width="90" x="179" y="390"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|word"/> </operator> <operator activated="true" class="append" compatibility="5.3.005" expanded="true" height="94" name="Append" width="90" x="313" y="210"/> <operator activated="true" class="remove_duplicates" compatibility="5.3.005" expanded="true" height="76" name="Remove Duplicates" width="90" x="447" y="210"/> <operator activated="true" class="nominal_to_text" compatibility="5.3.005" expanded="true" height="76" name="Nominal to Text" width="90" x="581" y="210"/> <operator activated="true" class="text:process_document_from_data" compatibility="5.3.000" expanded="true" height="76" name="Process Documents from Data" width="90" x="715" y="210"> <parameter key="vector_creation" value="Term Occurrences"/> <list key="specify_weights"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="5.3.000" expanded="true" height="60" name="Tokenize (5)" width="90" x="648" y="435"/> <connect from_port="document" to_op="Tokenize (5)" to_port="document"/> <connect from_op="Tokenize (5)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <connect from_op="Create Document" from_port="output" to_op="Process Documents" to_port="documents 1"/> <connect from_op="Create Document (2)" from_port="output" to_op="Process Documents (2)" to_port="documents 1"/> <connect from_op="Process Documents" from_port="word list" to_op="WordList to Data" to_port="word list"/> <connect from_op="WordList to Data" from_port="example set" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Append" to_port="example set 1"/> <connect from_op="Process Documents (2)" from_port="word list" to_op="WordList to Data (2)" to_port="word list"/> <connect from_op="WordList to Data (2)" from_port="example set" to_op="Select Attributes (2)" to_port="example set input"/> <connect from_op="Select Attributes (2)" from_port="example set output" to_op="Append" to_port="example set 2"/> <connect from_op="Append" from_port="merged set" to_op="Remove Duplicates" to_port="example set input"/> <connect from_op="Remove Duplicates" from_port="example set output" to_op="Nominal to Text" to_port="example set input"/> <connect from_op="Nominal to Text" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/> <connect from_op="Process Documents from Data" from_port="word list" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
