I'm having updating issues as well. Currently running 5.3.000. Haven't seen any updates since I moved to this version. When RapidMiner launches I see it checking for updates but it never finds any. It does not return any error message. If I try to force a check by going Help -> Updates and Extensions (MarketPlace) a window pops up saying Connecting to Marketplace server but eventually this times out. I get an error box which contains the details shown below. I have downloaded RapidMinerUpdate.exe to C:\Program Files\Rapid-I\RapidMiner5\scripts and rebooted but that did not seem to make any difference. I am behind a proxy server but that did not seem to interfer with earlier versions.
Exception: javax.xml.ws.WebServiceException
Message: Failed to access the WSDL at:
http://rapidupdate.de:80/UpdateServer/UpdateServiceService?wsdl. It failed with:
Got Connection timed out: connect while opening stream from
http://rapidupdate.de:80/UpdateServer/UpdateServiceService?wsdl.Stack trace:
com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.tryWithMex(Unknown Source)
com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.parse(Unknown Source)
com.sun.xml.internal.ws.client.WSServiceDelegate.parseWSDL(Unknown Source)
com.sun.xml.internal.ws.client.WSServiceDelegate.<init>(Unknown Source)
com.sun.xml.internal.ws.spi.ProviderImpl.createServiceDelegate(Unknown Source)
javax.xml.ws.Service.<init>(Unknown Source)
com.rapidminer.deployment.client.wsimport.UpdateServiceService.<init>(UpdateServiceService.java:42)
com.rapid_i.deployment.update.client.UpdateManager.getService(UpdateManager.java:563)
com.rapid_i.deployment.update.client.UpdateDialog$4.run(UpdateDialog.java:260)
com.rapidminer.gui.tools.ProgressThread$2.run(ProgressThread.java:189)
java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
java.lang.Thread.run(Unknown Source)
Cause
Exception: java.io.IOException
Message: Got Connection timed out: connect while opening stream from
http://rapidupdate.de:80/UpdateServer/UpdateServiceService?wsdlStack trace:
com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.createReader(Unknown Source)
com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.resolveWSDL(Unknown Source)
Cause
Exception: java.net.ConnectException
Message: Connection timed out: connect
Stack trace:
java.net.DualStackPlainSocketImpl.connect0(Native Method)
java.net.DualStackPlainSocketImpl.socketConnect(Unknown Source)
java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
java.net.AbstractPlainSocketImpl.connect(Unknown Source)
java.net.PlainSocketImpl.connect(Unknown Source)
java.net.SocksSocketImpl.connect(Unknown Source)
java.net.Socket.connect(Unknown Source)
sun.net.NetworkClient.doConnect(Unknown Source)
sun.net.www.http.HttpClient.openServer(Unknown Source)
sun.net.www.http.HttpClient.<init>(Unknown Source)
sun.net.www.http.HttpClient.New(Unknown Source)
sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(Unknown Source)
sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source)
sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
java.net.URL.openStream(Unknown Source)
