CSVExampleSource.PARAMETER_COLUMN_META_DATA
User: "Neomatrix433"
New Altair Community Member
Updated by Jocelyn
Hi I have a problem with the CSVExampelSource operator. I want to read a CSVDatei and add them to the DecisionTreeLearner.
How can I add my CSVExampelSource operator attributes and label?
This is my testdata:
Play;Outlook;Temperature;Humidity;Wind
yes;sunny;85;85.0;false
yes;overcast;80;90.0;true
no;overcast;83;78.0;false
no;rain;70;96.0;false
yes;rain;68;80.0;true
no;rain;65;70.0;true
yes;overcast;64;65.0;true
no;sunny;72;95.0;false
yes;sunny;69;70.0;false
no;sunny;75;80.0;false
yes;sunny;68;70.0;true
no;overcast;72;90.0;true
yes;overcast;81;75.0;true
no;rain;71;80.0;true
My code to test:
import java.io.File;
import java.util.LinkedList;
import java.util.List;
import com.rapidminer.Process;
import com.rapidminer.RapidMiner;
import com.rapidminer.RapidMiner.ExecutionMode;
import com.rapidminer.example.Attribute;
import com.rapidminer.example.Attributes;
import com.rapidminer.example.table.AttributeFactory;
import com.rapidminer.operator.IOContainer;
import com.rapidminer.operator.OperatorException;
import com.rapidminer.operator.learner.tree.DecisionTreeLearner;
import com.rapidminer.operator.nio.CSVExampleSource;
import com.rapidminer.operator.preprocessing.filter.ChangeAttributeRole;
import com.rapidminer.tools.Ontology;
import com.rapidminer.tools.OperatorService;
import de.tu_berlin.mf.vlcu.utilityclasses.CSVReader;
public class ProcessCreator {
  public static Process createProcess() {
    // invoke init before using the OperatorService
    RapidMiner.setExecutionMode(ExecutionMode.EMBEDDED_WITH_UI);
    RapidMiner.init();
    String dateipath1 = "./HLB_B3_Messung/Data_Controller/messung1/Testdaten.csv";
    File file = new File(dateipath1);
    CSVReader csvreader = new CSVReader(file.getAbsolutePath());
    csvreader.readCSV();
    String[] header = csvreader.getHeader();
    String[][] data = csvreader.getData();
    Process process = null;
    try {
      // create attribute list
      List<Attribute> attributes = new LinkedList<Attribute>();
      for (int a = 0; a < header.length; a++) {
        if (header.equals("Play")) {
          Attribute label = AttributeFactory.createAttribute("label", Ontology.NOMINAL);
          attributes.add(label);
        } else {
          attributes.add(AttributeFactory.createAttribute("att" + a, Ontology.REAL));
      // create process
      process = new Process();
      /* Reading Data */
      CSVExampleSource csvdata = OperatorService.createOperator(CSVExampleSource.class);
      // set parameters
      csvdata.setParameter(CSVExampleSource.PARAMETER_CSV_FILE, file.getAbsolutePath());
      csvdata.setParameter(CSVExampleSource.PARAMETER_FIRST_ROW_AS_NAMES, "true");
      csvdata.setParameter(CSVExampleSource.PARAMETER_COLUMN_SEPARATORS, ";");
      csvdata.setParameter(CSVExampleSource.PARAMETER_TRIM_LINES, "true");
      ChangeAttributeRole changerole = OperatorService.createOperator(ChangeAttributeRole.class);
      changerole.setParameter(ChangeAttributeRole.PARAMETER_NAME, "Play");
      changerole.setParameter(ChangeAttributeRole.PARAMETER_TARGET_ROLE, Attributes.LABEL_NAME);
      DecisionTreeLearner decisionTree = OperatorService.createOperator(DecisionTreeLearner.class);
      decisionTree.setParameter(DecisionTreeLearner.PARAMETER_CRITERION, "gain_ratio");
      decisionTree.setParameter(DecisionTreeLearner.PARAMETER_MINIMAL_SIZE_FOR_SPLIT, "4");
      decisionTree.setParameter(DecisionTreeLearner.PARAMETER_MINIMAL_LEAF_SIZE, "2");
      decisionTree.setParameter(DecisionTreeLearner.PARAMETER_MAXIMAL_DEPTH, "20");
      decisionTree.setParameter(DecisionTreeLearner.PARAMETER_CONFIDENCE, "0.25");
      process.getRootOperator().getSubprocess(0).addOperator(csvdata);
      process.getRootOperator().getSubprocess(0).addOperator(changerole);
      process.getRootOperator().getSubprocess(0).addOperator(decisionTree);
      csvdata.getOutputPorts().getPortByName("output")
          .connectTo(changerole.getInputPorts().getPortByName("example set input"));
      changerole.getOutputPorts().getPortByName("example set output")
          .connectTo(decisionTree.getInputPorts().getPortByName("training set"));
      // add other operators and set parameters
    } catch (Exception e) {
      e.printStackTrace();
    return process;
  public static void main(String[] argv) {
    // create process
    Process process = createProcess();
    // print process setup
    System.out.println(process.getRootOperator().createProcessTree(0));
    try {
      // perform process
      IOContainer test = process.run();
      System.out.println(test.toString());
      // to run the process with input created by your application use
      // process.run(new IOContainer(new IOObject[] { ... your objects ... });
    } catch (OperatorException e) {
and this is the output:
Process[0] (Process)
subprocess 'Main Process'
  +- Read CSV[0] (Read CSV)
  +- Set Role[0] (Set Role)
  +- Decision Tree[0] (Decision Tree)
IOContainer (0 objects):
How can I put information if nominal, binominal, real and integer to the CSV operator ....
How can I add to CSVExampelSource Metadata? that the Decision Tree is created by Rapidmineroperator over the label play.
I need urgent help, it's about my Bachelor
And prepare the prozess in rapidminer is not a alternative!!
Sorry for my bad english!!
MFG
1 - 13 of 131
    User: "Marco_Boeck"
    your output looks like you forgot to connect the output port of the last operator to the process output sink.
    Anyway, on to your questions:
    1) you need to set the parameter "data_set_meta_data_information" on your CSV operator to match the following list
             <parameter key="0" value="Play.true.binominal.attribute"/>
             <parameter key="1" value="Outlook.true.polynominal.attribute"/>
             <parameter key="2" value="Temperature.true.integer.attribute"/>
             <parameter key="3" value="Humidity.true.real.attribute"/>
             <parameter key="4" value="Wind.true.binominal.attribute"/>
    </list>
    2) Metadata is for process design help. As you are not using the RapidMiner design perspective to design your process you won't need it
    3) If you have exactly one label in your data, the DecisionTree will automatically use it
    As a general rule, if you need help on how certain parameters are named or how to use them, go to the RapidMiner design perspective, setup the operator in question there and then have a look at the process XML (XML tab next to the process). Name and values of all parameters can be seen there.
    Marco
    OP
    Thanks for the replay.
    I looked in the xml perpective and picked this out:
        RapidMiner.init();
        try {
          // create process
          /* Reading Data */
          // set parameters
          csvdata.setParameter(CSVExampleSource.PARAMETER_META_DATA,
              "<parameter key=\"0\" value=\"Play.true.nominal.label\"/>"
                  + "<parameter key=\"1\" value=\"Outlook.true.nominal.attribute\"/>"
                  + "<parameter key=\"2\" value=\"Temperature.true.integer.attribute\"/>"
                  + "<parameter key=\"3\" value=\"Humidity.true.integer.attribute\"/>"
                  + "<parameter key=\"4\" value=\"Wind .true.nominal.attribute\"/>");
          decisionTree.getOutputPorts().getPortByName("model")
              .connectTo(process.getRootOperator().getInputPorts().getPortByName("result 1"));
        return process;
        // create process
        try {
          // perform process
    then run the Code and the output is:
    01.03.2013 14:14:33 com.rapidminer.tools.WrapperLoggingHandler log
    INFO: No filename given for result file, using stdout for logging results!
    01.03.2013 14:14:33 com.rapidminer.Process run
    INFO: Process starts
    com.rapidminer.operator.UserError: Input example set does not have a label attribute
    at com.rapidminer.operator.learner.AbstractLearner.doWork(AbstractLearner.java:139)
    at com.rapidminer.operator.Operator.execute(Operator.java:834)
    at com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:51)
    at com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:711)
    at com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:379)
    at com.rapidminer.Process.run(Process.java:925)
    at com.rapidminer.Process.run(Process.java:848)
    at com.rapidminer.Process.run(Process.java:807)
    at com.rapidminer.Process.run(Process.java:802)
    at com.rapidminer.Process.run(Process.java:792)
    at de.tu_berlin.mf.vlcu.test.ProcessCreator.main(ProcessCreator.java:95)
    What is rong? connecting in this line is correct?
    i guess the line
    is not correct.
    This can i read in the errormessage: Input example set does not have a label attribute.
    Can anyone show me a Codesample to do this correct?
    Thanks and regards
    User: "Marco_Boeck"
    obviously you cannot use the xml snippet I quoted as a parameter, I merely pointed out the names of the key/value pairs for the list parameter. See ParameterTypeList class and its use in the RapidMiner sourcecode for further details. I guess you will need to dig quite a bit through the RapidMiner sourcecode seeing as for some reason you don't want to use the much less tedious and less error-prone approach to design your processes in the GUI instead of coding everything by hand from scratch.
    Marco
    OP
    I read the source code of rapidminer (svn Vega i know http://svn.code.sf.net/p/rapidminer/code/Unuk RapidMiner_Unuk is current  ;D) but it is very difficult to find the place in the code.
    User: "aborg"
    Would you prefer github?
    Imho the best is a good IDE for navigation, but having relevant messages for commits would be a welcomed change.
    PS.: my fork is a bit out of date, not yet imported the changes since 5.3.5.
    OP
    No SVN is ok i use this form my own projekts  ;)
    and the vision is ok. I use the search funktion of my IDE Eclipse is very helpfull  8) to find the code places in rapidminer.
    is the difference between 5.2 and 5.3.5 so great in reference of my problem?
    best regards from berlin  ;D
    OP
    i search this function in the code of rapidminer but i cant fund this!
    pleace give me a hint to find this in the code, i guess it´s the solution part of my problem.
    User: "Marco_Boeck"
    that is also a parameter of the CSVExampleSource operator, and it is the one I showed you earlier. You will have to create a ParameterTypeList object, fill it with the given key/value pairs and then add that object to the CSVExampleSource instance under the "data_set_meta_data_information" key.
    Marco
    OP
    Thanks for the help.
    I have change the code:
    import java.util.ArrayList;
        // RapidMiner.setExecutionMode(ExecutionMode.EMBEDDED_WITH_UI);
        RapidMiner.init();
        try {
          // create process
          /* Reading Data */
          List<String[]> parametertyplist = new ArrayList<String[]>();
          parametertyplist.add(new String[] { "0", "Play.true.nominal.label" });
          parametertyplist.add(new String[] { "1", "Outlook.true.nominal.attribute" });
          parametertyplist.add(new String[] { "2", "Temperature.true.integer.attribute" });
          parametertyplist.add(new String[] { "3", "Humidity.true.integer.attribute" });
          parametertyplist.add(new String[] { "4", "Wind .true.nominal.attribute" });
          csvdata.setListParameter(CSVExampleSource.PARAMETER_META_DATA, parametertyplist);
          decisionTree.getOutputPorts().getPortByName("exampleSet")
              .connectTo(process.getRootOperator().getInputPorts().getPortByName("result 2"));
        return process;
        // create process
        try {
          // perform process
    and the result is:
    01.03.2013 20:27:44 com.rapidminer.tools.WrapperLoggingHandler log
    01.03.2013 20:27:44 com.rapidminer.Process run
    INFO: Process finished successfully after 0 s
    The Problem with label and attributes looks solved......
    IOContainer (o objects) what is wrong now ::) ??? ??? ??? ???
    What is the problem now? I am a nervous wreck!
    User: "aborg"
      Could this help you to solve this problem?
    HTH, gabor
    OP
    Yes but only the problem with the meta data information for the decision tree.
    the iocontainer is still clear!!
        /* Reading Data */
        parametertyplist.add(new String[] { "4", "Wind.true.nominal.attribute" });
        List<String[]> annotationlist = new ArrayList<String[]>();
        annotationlist.add(new String[] { "0", "Name" });
        csvdata.setParameter(CSVExampleSource.PARAMETER_FIRST_ROW_AS_NAMES, "false");
        csvdata.setParameter("encoding", "windows-1252");
        csvdata.setListParameter(CSVExampleSource.PARAMETER_ANNOTATIONS, annotationlist);
        DataResultSetFactory factory = new CSVResultSetConfiguration(csvdata);
        DataResultSetTranslationConfiguration config = new DataResultSetTranslationConfiguration(csvdata);
        // Configure data resultset translation configuration ...
        DataResultSet dataresultset = factory.makeDataResultSet(csvdata);
        DataResultSetTranslator translator = new DataResultSetTranslator(csvdata);
        try {
          ExampleSet cachedExampleSet = translator.read(dataresultset, config, false, null);
          System.out.println(cachedExampleSet.toResultString());
          return new IOContainer(new IOObject[] { cachedExampleSet });
        } finally {
          translator.close();
    this is the output of cachedExampleSet :
    SimpleExampleSet:
    14 examples,
    4 regular attributes,
    special attributes = {
        label = #0: Play (nominal/single_value)/values=[yes, no]
    the right output should be:
    IOContainer (2 objects):
    Humidity > 92.500: no {yes=0, no=2}
    Humidity ≤ 92.500: yes {yes=7, no=5}
    (created by Decision Tree)
    SimpleExampleSet:
    14 examples,
    (created by Read CSV)
    when I use the process in rapidminer create and export and run this in my own code!
    User: "aborg"
    Sorry, no experience in this regard, but this might help.
    Cheers, gabor
    OP
    My solution for this Problem:
    Create a simpel prozess in rapidminer:
    and export the prozess with rapidminer in file DecisionTreeprozess.rmp
    then use the prozess in my own code:
    import java.util.Iterator;
    import com.rapidminer.operator.Operator;
      private static final String CSVDATEI = "./HLB_B3_Messung/Data_Controller/messung1/Testdaten.csv";
      private static final String PROZESSDATEI = "./HLB_B3_Messung/Data_Controller/messung1/DecisionTreeprozess.rmp";
        RapidMiner.setExecutionMode(ExecutionMode.EMBEDDED_WITHOUT_UI);
        RapidMiner.init();
        try {
          // create process
          process = new Process(new File(PROZESSDATEI).getAbsoluteFile());
          // get the list of prozess operators
          List<Operator> operatorlist = process.getRootOperator().getSubprocess(0).getOperators();
          Iterator<Operator> iter = operatorlist.iterator();
          // iterating over the list and set parameters
          while (iter.hasNext()) {
            Operator operator = (Operator) iter.next();
            System.out.println(operator.getName());
            if (operator.getName().equals("Read CSV")) { // check Read CSV
                                                        // operator if true set the
                                                        // parameter to the
                                                        // operator
              List<String[]> parametertyplist = new ArrayList<String[]>(); // meta
        // data
        // for
        // table
        // data
              List<String[]> annotationlist = new ArrayList<String[]>(); // set
        // annotations
        // for
        // columns
              operator.setParameter(CSVExampleSource.PARAMETER_CSV_FILE, new File(CSVDATEI).getAbsoluteFile().toString());
              operator.setParameter(CSVExampleSource.PARAMETER_FIRST_ROW_AS_NAMES, "false");
              operator.setParameter(CSVExampleSource.PARAMETER_COLUMN_SEPARATORS, ";");
              operator.setParameter("encoding", "windows-1252");
              operator.setListParameter(CSVExampleSource.PARAMETER_META_DATA, parametertyplist);
              operator.setListParameter(CSVExampleSource.PARAMETER_ANNOTATIONS, annotationlist);
            } else if (operator.getName().equals("Decision Tree")) { // check
        // Decision
        // Tree
        // operator if
        // true set the
        // parameter to
        // the operator
              operator.setParameter(DecisionTreeLearner.PARAMETER_CRITERION, "gain_ratio");
              operator.setParameter(DecisionTreeLearner.PARAMETER_MINIMAL_SIZE_FOR_SPLIT, "4");
              operator.setParameter(DecisionTreeLearner.PARAMETER_MINIMAL_LEAF_SIZE, "2");
              operator.setParameter(DecisionTreeLearner.PARAMETER_MAXIMAL_DEPTH, "20");
              operator.setParameter(DecisionTreeLearner.PARAMETER_CONFIDENCE, "0.25");
            // so on check other operators and set parameters when you have more
            // operator in prozess
        return process;
        // create process
        try {
          // perform process
          IOContainer ioResult = process.run();
          // print result
          System.out.println(ioResult.toString());
    Output of this code:
    Read CSV
    Decision Tree
    02.03.2013 14:18:48 com.rapidminer.tools.WrapperLoggingHandler log
    02.03.2013 14:18:48 com.rapidminer.Process run
    INFO: Process D:\Anwendungsentwicklung\eclipse 64 Bit\workspace\VLCU_Neu\.\HLB_B3_Messung\Data_Controller\messung1\DecisionTreeprozess.rmp starts
    INFO: Process D:\Anwendungsentwicklung\eclipse 64 Bit\workspace\VLCU_Neu\.\HLB_B3_Messung\Data_Controller\messung1\DecisionTreeprozess.rmp finished successfully after 0 s
    SimpleExampleSet:
    14 examples,
    Thanks to all helper!!!
    pleace close this thread.
