I can´t change the dimensions of any element. The following warning window appears:
This is quite strange. You should be able to change any dimension or parameter without the need to create variables.
Keep in mind that you can not create variables names using numbers (It is not allowed)
Please check if by mistake you've created an invalid variable and delete it.
Does this happen always or only with a specific file? In case it happens with a specific file please sent it to the technical support to be checked.
Hope this helps.
Regards
Adel Matar
