<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process"> <process expanded="true" height="460" width="547"> <operator activated="true" class="generate_concatenation" compatibility="5.3.000" expanded="true" height="76" name="Generate Concatenation" width="90" x="179" y="165"> <parameter key="first_attribute" value="Illness"/> <parameter key="second_attribute" value="Location"/> </operator> <operator activated="true" class="loop_values" compatibility="5.3.000" expanded="true" height="76" name="Loop Values" width="90" x="313" y="165"> <parameter key="attribute" value="Illness_Location"/> <process expanded="true" height="663" width="887"> <operator activated="true" class="filter_examples" compatibility="5.3.000" expanded="true" height="76" name="Filter Examples" width="90" x="179" y="30"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="Illness_Location=%{loop_value}"/> </operator> <connect from_port="example set" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_port="out 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_op="Generate Concatenation" from_port="example set output" to_op="Loop Values" to_port="example set"/> <connect from_op="Loop Values" from_port="out 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
