i have just updated the RapidMiner version to 5.3
i am using crawl web operator and specifying directory. but i am getting 'Failed to create directory' error.
i cannot understand why it is happening because i was successfully able to execute the same process before upgrading the version.
ive added my process code.
Please help!
Thanks,
Vineet
<process version="5.3.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process">
<process expanded="true" height="579" width="748">
<operator activated="true" class="web:crawl_web" compatibility="5.3.000" expanded="true" height="60" name="Crawl Web" width="90" x="112" y="30">
<parameter key="url" value="https://twitter.com/search?q=iphone&src=typd"/>
<list key="crawling_rules"/>
<parameter key="add_pages_as_attribute" value="true"/>
<parameter key="output_dir" value="C:\Users\vnagpal\Desktop\Crawl"/>
<parameter key="max_pages" value="1"/>
<parameter key="max_depth" value="1"/>
<parameter key="max_threads" value="4"/>
<parameter key="max_page_size" value="1000"/>
<parameter key="user_agent" value=" Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.4 (KHTML, like Gecko) Chrome/22.0.1229.12 Safari/537.4 "/>
<connect from_op="Crawl Web" from_port="Example Set" to_port="result 1"/>
</process>
</process>
