i have a small outlier detection process that i need to invoke from command line.
The process works fine from rapidMiner GUI.
When run from command line, the process does the job but spews out error messages (pasted below).
Can you tell me what could be the reason behind these messages?
This is Windows 7 OS and RapidMiner 5 (Community Edition). It connects to SQL Server 2012 database.
RAPIDMINER_HOME and JRE_HOME environment variables are set as follows:
RAPIDMINER_HOME=D:\Program Files\Rapid-I\RapidMiner5
JRE_HOME=C:\Program Files\Java\jdk1.6.0_31
\Program Files\Rapid-I\RapidMiner5>.\scripts\rapidminer //RapidMinerLocalRepository001/db1
Using local jre:
\Program Files\Rapid-I\RapidMiner5\jre\bin\java.exe...
Starting RapidMiner from 'D:\Program Files\Rapid-I\RapidMiner5' using classes from 'D:\Program Files\Rapid-I\RapidMiner5\lib\rapidminer.jar'...
RapidMiner version 5.2.008, Copyright (C) 2001-2012
RapidMiner comes with ABSOLUTELY NO WARRANTY; This is free software,
and you are welcome to redistribute it under certain conditions;
see license information in the file named LICENSE.
Jan 21, 2013 5:53:49 PM com.rapid_i.Launcher ensureRapidMinerHomeSet
INFO: rapidminer.home is 'D:\Program Files\Rapid-I\RapidMiner5'.
Jan 21, 2013 5:53:49 PM com.rapidminer.tools.ParameterService init
INFO: Reading configuration resource com/rapidminer/resources/rapidminerrc.
Jan 21, 2013 5:53:49 PM com.rapidminer.tools.I18N <clinit>
INFO: Set locale to en.
Jan 21, 2013 5:53:50 PM com.rapidminer.parameter.ParameterTypePassword decryptPassword
WARNING: Password in XML file looks like unencrypted plain text.
Jan 21, 2013 5:53:51 PM com.rapidminer.operator.LifeStyle_Marketing.LifeStyle_Targeting WriteLog
SEVERE: Error com.rapidminer.operator.ports.metadata.MetaData cannot be cast to
com.rapidminer.operator.ports.metadata.ExampleSetMetaData .
Jan 21, 2013 5:53:51 PM com.rapidminer.tools.OperatorService parseOperators
WARNING: Cannot create operator description: rmx_imageprocessing : wand_tool
java.lang.NoClassDefFoundError: com/rapidminer/parameter/conditions/InputPortNot
ConnectedCondition
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at com.rapidminer.operator.OperatorDescription.<init>(OperatorDescription.java:93)
at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.java:300)
at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.java:293)
at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.java:269)
at com.rapidminer.tools.OperatorService.registerOperators(OperatorService.java:231)
at com.rapidminer.tools.plugin.Plugin.registerOperators(Plugin.java:483)
at com.rapidminer.tools.plugin.Plugin.registerAllPluginOperators(Plugin.java:782)
at com.rapidminer.tools.OperatorService.init(OperatorService.java:182)
at com.rapidminer.RapidMiner.init(RapidMiner.java:514)
at com.rapidminer.RapidMinerCommandLine.run(RapidMinerCommandLine.java:122)
at com.rapidminer.RapidMinerCommandLine.main(RapidMinerCommandLine.java:182)
Caused by: java.lang.ClassNotFoundException: com.rapidminer.parameter.conditions.InputPortNotConnectedCondition
at java.net.URLClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(Unknown Source)
at com.rapidminer.tools.plugin.PluginClassLoader.loadClass(PluginClassLoader.java:102)
at java.lang.ClassLoader.loadClass(Unknown Source)
... 15 more
Jan 21, 2013 5:53:51 PM com.rapidminer.tools.jdbc.JDBCProperties <init>
WARNING: Missing database driver class name for ODBC Bridge (e.g. Access)
Jan 21, 2013 5:53:51 PM com.rapidminer.tools.jdbc.JDBCProperties registerDrivers
INFO: JDBC driver ca.ingres.jdbc.IngresDriver not found. Probably the driver is
not installed.
INFO: JDBC driver oracle.jdbc.driver.OracleDriver not found. Probably the driver
is not installed.
Jan 21, 2013 5:53:51 PM com.rapidminer.tools.WrapperLoggingHandler log
INFO: No filename given for result file, using stdout for logging results!
Jan 21, 2013 5:53:51 PM com.rapidminer.Process run
INFO: Process //RapidMinerLocalRepository001/db1 starts
Jan 21, 2013 5:53:51 PM com.rapidminer.tools.jdbc.DatabaseHandler executeStateme
nt
INFO: Executing query: 'SELECT *
FROM "dbo"."mvi_claims_data"'
Jan 21, 2013 5:53:52 PM com.rapidminer.Process run
INFO: Process //RapidMinerLocalRepository001/db1 finished successfully after 0 s
Jan 21, 2013 5:53:52 PM com.rapidminer.RapidMinerCommandLine run
INFO: Process finished successfully
Usage: java [-options] class [args...]
(to execute a class)
or java [-options] -jar jarfile [args...]
(to execute a jar file)
where options include:
-client to select the "client" VM
-server to select the "server" VM
-hotspot is a synonym for the "client" VM [deprecated]
The default VM is client.
-cp <class search path of directories and zip/jar files>
-classpath <class search path of directories and zip/jar files>
A ; separated list of directories, JAR archives,
and ZIP archives to search for class files.
-D<name>=<value>
set a system property
-verbose[:class|gc|jni]
enable verbose output
-version print product version and exit
-version:<value>
require the specified version to run
-showversion print product version and continue
-jre-restrict-search | -jre-no-restrict-search
include/exclude user private JREs in the version search
-? -help print this help message
-X print help on non-standard options
-ea[:<packagename>...|:<classname>]
-enableassertions[:<packagename>...|:<classname>]
enable assertions
-da[:<packagename>...|:<classname>]
-disableassertions[:<packagename>...|:<classname>]
disable assertions
-esa | -enablesystemassertions
enable system assertions
-dsa | -disablesystemassertions
disable system assertions
-agentlib:<libname>[=<options>]
load native agent library <libname>, e.g. -agentlib:hprof
see also, -agentlib:jdwp=help and -agentlib:hprof=help
-agentpath:<pathname>[=<options>]
load native agent library by full pathname
-javaagent:<jarpath>[=<options>]
load Java programming language agent, see java.lang.instrument
-splash:<imagepath>
show splash screen with specified image
Process screenshot here:
http://nbstoragemahesh.blob.core.windows.net/jbsbsorba/rm3.pngProcess XML here:
http://nbstoragemahesh.blob.core.windows.net/jbsbsorba/f1.xml
