<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <process expanded="true" height="161" width="279"> <operator activated="true" class="text:process_document_from_file" compatibility="5.2.004" expanded="true" height="76" name="Process Documents from Files" width="90" x="179" y="75"> <list key="text_directories"> <parameter key="doc1" value="C:\Users\marcos\Desktop\Datos de prueba para clustering\Caso de prueba 2\En español\doc1"/> <parameter key="doc2" value="C:\Users\marcos\Desktop\Datos de prueba para clustering\Caso de prueba 2\En español\doc2"/> <parameter key="doc3" value="C:\Users\marcos\Desktop\Datos de prueba para clustering\Caso de prueba 2\En español\doc3"/> </list> <process expanded="true" height="415" width="758"> <operator activated="true" class="text:transform_cases" compatibility="5.2.004" expanded="true" height="60" name="Transform Cases" width="90" x="45" y="30"/> <operator activated="true" class="text:tokenize" compatibility="5.2.004" expanded="true" height="60" name="Tokenize" width="90" x="45" y="120"/> <operator activated="true" class="text:filter_stopwords_dictionary" compatibility="5.2.004" expanded="true" height="76" name="Filter stopwords_pronombres_preposiciones" width="90" x="45" y="210"> <parameter key="file" value="C:\Users\marcos\Desktop\stopwords\stopwords_pronombres_preposiciones.txt"/> </operator> <operator activated="true" class="text:filter_stopwords_dictionary" compatibility="5.2.004" expanded="true" height="76" name="Filter stopwords_caratula" width="90" x="45" y="300"> <parameter key="file" value="C:\Users\marcos\Desktop\stopwords\stopwords_caratula.txt"/> </operator> <operator activated="true" class="text:filter_stopwords_english" compatibility="5.2.004" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="179" y="30"/> <operator activated="true" class="text:filter_by_length" compatibility="5.2.004" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="179" y="120"> <parameter key="min_chars" value="3"/> </operator> <operator activated="true" class="k_means" compatibility="5.2.008" expanded="true" height="76" name="Clustering" width="90" x="336" y="179"/> <connect from_port="document" to_op="Transform Cases" to_port="document"/> <connect from_op="Transform Cases" from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Filter stopwords_pronombres_preposiciones" to_port="document"/> <connect from_op="Filter stopwords_pronombres_preposiciones" from_port="document" to_op="Filter stopwords_caratula" to_port="document"/> <connect from_op="Filter stopwords_caratula" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/> <connect from_op="Filter Stopwords (English)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/> <connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Clustering" to_port="example set"/> <connect from_op="Clustering" from_port="cluster model" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <connect from_op="Process Documents from Files" from_port="example set" to_port="result 1"/> <connect from_op="Process Documents from Files" from_port="word list" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process"> <process expanded="true" height="516" width="433"> <operator activated="true" class="text:process_document_from_file" compatibility="5.2.005" expanded="true" height="76" name="Process Documents from Files" width="90" x="112" y="30"> <list key="text_directories"> <parameter key="doc1" value="C:\Users\marcos\Desktop\Datos de prueba para clustering\Caso de prueba 2\En español\doc1"/> <parameter key="doc2" value="C:\Users\marcos\Desktop\Datos de prueba para clustering\Caso de prueba 2\En español\doc2"/> <parameter key="doc3" value="C:\Users\marcos\Desktop\Datos de prueba para clustering\Caso de prueba 2\En español\doc3"/> </list> <process expanded="true" height="516" width="705"> <operator activated="true" class="text:transform_cases" compatibility="5.2.005" expanded="true" height="60" name="Transform Cases" width="90" x="45" y="30"/> <operator activated="true" class="text:tokenize" compatibility="5.2.005" expanded="true" height="60" name="Tokenize" width="90" x="180" y="30"/> <operator activated="true" class="text:filter_stopwords_dictionary" compatibility="5.2.005" expanded="true" height="76" name="Filter stopwords_pronombres_preposiciones" width="90" x="315" y="30"> <parameter key="file" value="C:\Users\marcos\Desktop\stopwords\stopwords_pronombres_preposiciones.txt"/> </operator> <operator activated="true" class="text:filter_stopwords_dictionary" compatibility="5.2.005" expanded="true" height="76" name="Filter stopwords_caratula" width="90" x="450" y="30"> <parameter key="file" value="C:\Users\marcos\Desktop\stopwords\stopwords_caratula.txt"/> </operator> <operator activated="true" class="text:filter_stopwords_english" compatibility="5.2.005" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="581" y="30"/> <operator activated="true" class="text:filter_by_length" compatibility="5.2.005" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="313" y="210"> <parameter key="min_chars" value="3"/> </operator> <connect from_port="document" to_op="Transform Cases" to_port="document"/> <connect from_op="Transform Cases" from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Filter stopwords_pronombres_preposiciones" to_port="document"/> <connect from_op="Filter stopwords_pronombres_preposiciones" from_port="document" to_op="Filter stopwords_caratula" to_port="document"/> <connect from_op="Filter stopwords_caratula" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/> <connect from_op="Filter Stopwords (English)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/> <connect from_op="Filter Tokens (by Length)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="162"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="k_means" compatibility="5.3.000" expanded="true" height="76" name="Clustering" width="90" x="313" y="30"/> <connect from_op="Process Documents from Files" from_port="example set" to_op="Clustering" to_port="example set"/> <connect from_op="Clustering" from_port="cluster model" to_port="result 1"/> <connect from_op="Clustering" from_port="clustered set" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
