Hello everyone, I was wondering if it is somehow possible to recreate the far field of a specific patch Antenna using its technical datasheet. I managed to recreate the 3D radiation pattern using AMAN by recreating the 2D horizontal and vertical radiation patterns from the datasheet and then converting both to a 3D pattern. I can't use this information, however, to recreate this specific pattern in CADfeko using the far field source option. Is there any other way this can be accomplished?
