I'm using text data that contains three attribute (NAME, LABEL, DOMAIN), this is a sample of the data:
NAME LABEL DOMAIN
origin from string
destination to string
departure day day date
departure month month date
I want to use k-means clustering operator in order to cluster the data, but unfortunately I got this ERROR before the execution:
" The setup does not seem to contain any obvious error, but you should check the log messages or activate the debug mode in the setting dialog in order to get more information about this problem"Here it is the Log Messages:
Dec 26, 2012 1:23:44 AM INFO: Process //NewLocalRepository/IOS/EM starts
Dec 26, 2012 1:23:44 AM INFO: Loading initial data.
Dec 26, 2012 1:23:45 AM SEVERE: Process failed: operator cannot be executed. Check the log messages...
Dec 26, 2012 1:23:45 AM SEVERE: Here: Process[1] (Process)
subprocess 'Main Process'
+- Retrieve[1] (Retrieve)
==> +- Clustering[1] (k-Means)
Dec 26, 2012 1:23:45 AM SEVERE: java.lang.NullPointerExceptionand here it is the XML :
<process version="5.2.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
<process expanded="true" height="341" width="480">
<operator activated="true" class="retrieve" compatibility="5.2.008" expanded="true" height="60" name="Retrieve" width="90" x="126" y="140">
<parameter key="repository_entry" value="../EXPIO/DDP"/>
<operator activated="true" class="k_means" compatibility="5.2.008" expanded="true" height="76" name="Clustering" width="90" x="313" y="120">
<parameter key="k" value="10"/>
<parameter key="measure_types" value="NominalMeasures"/>
<parameter key="nominal_measure" value="DiceSimilarity"/>
<connect from_op="Retrieve" from_port="output" to_op="Clustering" to_port="example set"/>
<connect from_op="Clustering" from_port="cluster model" to_port="result 1"/>
</process>
</process>
Any advice would be greatly appreciated. Thanks!
