As suggested by Marco Boeck(administrator) i have used rapid miner GUI for creating process in which i used readDatabase operator read table from  mysql data base and used it as a input to LOF operator and there after output of LOF operator was given to writeDatabase operator. process so created was called from java application, but when compiled it gives error on database connection variable 'netcon' which i have defined using GUI and was working well there. Then why is it not finding it when being called from java application. my java code is as follows.
package pkg;
import java.io.IOException;
import com.rapidminer.RapidMiner;
import com.rapidminer.RapidMiner.ExecutionMode;
import com.rapidminer.example.ExampleSet;
import com.rapidminer.operator.IOContainer;
import com.rapidminer.operator.IOObject;
import com.rapidminer.operator.Operator;
import com.rapidminer.operator.OperatorException;
import com.rapidminer.repository.IOObjectEntry;
import com.rapidminer.repository.MalformedRepositoryLocationException;
import com.rapidminer.repository.ProcessEntry;
import com.rapidminer.repository.RepositoryException;
import com.rapidminer.repository.RepositoryLocation;
import com.rapidminer.tools.XMLException;
import com.rapidminer.Process;
public class trydatabase {
	 * @param args
	public static void main(String[] args)
		// TODO Auto-generated method stub
		// this initializes RapidMiner with your repositories available
		// you have to call this for all your programs, otherwise your RapidMiner integration will not work correctly
		RapidMiner.setExecutionMode(ExecutionMode.COMMAND_LINE);
		RapidMiner.init();
		// loads the process from the repository
		RepositoryLocation pLoc = null;
		try
			pLoc = new RepositoryLocation("//NewLocalRepository/createOutlier");
		catch (MalformedRepositoryLocationException e1)
			// TODO Auto-generated catch block
			e1.printStackTrace();
		ProcessEntry pEntry = null;
		try
			pEntry = (ProcessEntry) pLoc.locateEntry();
		catch (RepositoryException e1)
		String processXML = null;
		try
			processXML = pEntry.retrieveXML();
		Process myProcess = null;
		try
			myProcess = new Process(processXML);
		catch (IOException e1)
		catch (XMLException e1)
		try
			myProcess.run();
		catch (OperatorException e)
			e.printStackTrace();
And my XML process code is as follows
<process version="5.2.008">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
    <process expanded="true" height="235" width="681">
      <operator activated="true" class="read_database" compatibility="5.2.008" expanded="true" height="60" name="Read Database" width="90" x="47" y="177">
        <parameter key="connection" value="netcon"/>
        <parameter key="query" value="SELECT *
FROM `nettable`"/>
        <enumeration key="parameters"/>
      <operator activated="true" class="anomalydetection:Local Outlier Factor (LOF)" compatibility="1.2.000" expanded="true" height="76" name="Local Outlier Factor (LOF)" width="90" x="226" y="164">
        <parameter key="k_max (MinPtsUB)" value="18"/>
      <operator activated="true" class="write_database" compatibility="5.2.008" expanded="true" height="60" name="Write Database" width="90" x="471" y="182">
        <parameter key="table_name" value="resulttable"/>
      <connect from_op="Read Database" from_port="output" to_op="Local Outlier Factor (LOF)" to_port="example set"/>
      <connect from_op="Local Outlier Factor (LOF)" from_port="example set" to_op="Write Database" to_port="input"/>
      <connect from_op="Write Database" from_port="through" to_port="result 1"/>
    </process>
</process>
Error which i am getting is
Dec 22, 2012 1:40:07 PM com.rapidminer.tools.ParameterService init
INFO: Reading configuration resource com/rapidminer/resources/rapidminerrc.
Dec 22, 2012 1:40:07 PM com.rapidminer.tools.I18N <clinit>
INFO: Set locale to en.
Dec 22, 2012 1:40:07 PM com.rapid_i.Launcher ensureRapidMinerHomeSet
INFO: Property rapidminer.home is not set. Guessing.
INFO: Trying parent directory of '/home/iitm/workspace/rapidminer/rapidminer.jar'...gotcha!
INFO: Trying parent directory of '/opt/rapidminer/lib/rapidminer.jar'...gotcha!
INFO: Trying parent directory of '/opt/rapidminer/lib/launcher.jar'...gotcha!
Dec 22, 2012 1:40:08 PM com.rapidminer.parameter.ParameterTypePassword decryptPassword
WARNING: Password in XML file looks like unencrypted plain text.
Dec 22, 2012 1:40:09 PM com.rapidminer.tools.jdbc.JDBCProperties <init>
WARNING: Missing database driver class name for ODBC Bridge (e.g. Access)
Dec 22, 2012 1:40:09 PM com.rapidminer.tools.jdbc.JDBCProperties registerDrivers
INFO: JDBC driver ca.ingres.jdbc.IngresDriver not found. Probably the driver is not installed.
INFO: JDBC driver oracle.jdbc.driver.OracleDriver not found. Probably the driver is not installed.
Dec 22, 2012 1:40:09 PM com.rapidminer.tools.WrapperLoggingHandler log
INFO: No filename given for result file, using stdout for logging results!
Dec 22, 2012 1:40:09 PM com.rapidminer.Process run
INFO: Process starts
com.rapidminer.operator.UserError: Database connection failed: connection netcon is unknown. Please define the connection properly.
	at com.rapidminer.tools.jdbc.DatabaseHandler.getConnectedDatabaseHandler(DatabaseHandler.java:1038)
	at com.rapidminer.operator.io.DatabaseDataReader.getResultSet(DatabaseDataReader.java:111)
	at com.rapidminer.operator.io.DatabaseDataReader.createExampleSet(DatabaseDataReader.java:124)
	at com.rapidminer.operator.io.AbstractExampleSource.read(AbstractExampleSource.java:52)
	at com.rapidminer.operator.io.DatabaseDataReader.read(DatabaseDataReader.java:96)
	at com.rapidminer.operator.io.DatabaseDataReader.read(DatabaseDataReader.java:82)
	at com.rapidminer.operator.io.AbstractReader.doWork(AbstractReader.java:123)
	at com.rapidminer.operator.Operator.execute(Operator.java:834)
	at com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:51)
	at com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:711)
	at com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:379)
	at com.rapidminer.Process.run(Process.java:925)
	at com.rapidminer.Process.run(Process.java:848)
	at com.rapidminer.Process.run(Process.java:807)
	at com.rapidminer.Process.run(Process.java:802)
	at com.rapidminer.Process.run(Process.java:792)
	at pkg.trydatabase.main(trydatabase.java:87)
Can you please suggest some solution please
