operator.setParameter(SingleDocumentInputOperator.PARAMETER_TEXT, "your text");
Process rm5 = new Process(); rm5 = new Process(new File(directory + "/src/Tokenizer.xml")); Operator.setParameter(SingleDocumentInputOperator.PARAMETER_TEXT, "your text"); System.out.println("Init Fertitsch"); rm5.run();
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <parameter key="logverbosity" value="all"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <parameter key="parallelize_main_process" value="false"/> <process expanded="true" height="415" width="835"> <operator activated="true" class="text:create_document" compatibility="5.2.004" expanded="true" height="60" name="Create Document" width="90" x="23" y="44"> <parameter key="text" value="Hi das ist der Prozess den ich ausführen möchte!"/> <parameter key="add label" value="false"/> <parameter key="label_type" value="nominal"/> </operator> <operator activated="true" class="text:tokenize" compatibility="5.2.004" expanded="true" height="60" name="Tokenize" width="90" x="180" y="30"> <parameter key="mode" value="non letters"/> <parameter key="characters" value=".:"/> <parameter key="language" value="English"/> <parameter key="max_token_length" value="3"/> </operator> <operator activated="true" class="text:transform_cases" compatibility="5.2.004" expanded="true" height="60" name="Transform Cases" width="90" x="315" y="30"> <parameter key="transform_to" value="lower case"/> </operator> <operator activated="true" class="text:filter_stopwords_german" compatibility="5.2.004" expanded="true" height="60" name="Filter Stopwords (German)" width="90" x="450" y="30"> <parameter key="stop_word_list" value="Standard"/> </operator> <operator activated="true" class="text:stem_german" compatibility="5.2.004" expanded="true" height="60" name="Stem (German)" width="90" x="45" y="165"/> <operator activated="true" class="text:filter_by_length" compatibility="5.2.004" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="313" y="165"> <parameter key="min_chars" value="2"/> <parameter key="max_chars" value="25"/> </operator> <connect from_op="Create Document" from_port="output" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/> <connect from_op="Transform Cases" from_port="document" to_op="Filter Stopwords (German)" to_port="document"/> <connect from_op="Filter Stopwords (German)" from_port="document" to_op="Stem (German)" to_port="document"/> <connect from_op="Stem (German)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/> <connect from_op="Filter Tokens (by Length)" from_port="document" to_port="result 1"/> <portSpacing port="source_input 1" spacing="108"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
Process rm5 = new Process(); //System.out.println("Init Finished"); try { // create operator Operator inputOperator = OperatorService.createOperator(SingleDocumentInputOperator.class); // set parameters inputOperator.setParameter(SingleDocumentInputOperator.PARAMETER_TEXT, "your text das ist der tolle text der uns jetzt gerade interessiertetn tut"); // add operator to process // add other operators and set parameters // [...] } catch (Exception e) { e.printStackTrace(); } rm5 = new Process(new File(directory + "/src/Tokenizer.xml")); // just use myProcess.run() if you don't use the input ports for your process IOContainer ioResult = rm5.run(); System.out.println(ioResult);
process.getOperator("Create Document").setParameter(SingleDocumentInputOperator.PARAMETER_TEXT, "your Text");
