<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <process expanded="true" height="431" width="1016"> <operator activated="true" class="retrieve" compatibility="5.2.008" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.2.008" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="165"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|a4|a3|a2|a1"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="k_means" compatibility="5.2.008" expanded="true" height="76" name="Clustering" width="90" x="313" y="30"> <parameter key="k" value="3"/> <parameter key="measure_types" value="NumericalMeasures"/> <parameter key="numerical_measure" value="CosineSimilarity"/> </operator> <operator activated="true" class="replace" compatibility="5.2.008" expanded="true" height="76" name="Replace" width="90" x="313" y="300"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="id"/> <parameter key="include_special_attributes" value="true"/> <parameter key="replace_what" value="id_(.*)"/> <parameter key="replace_by" value="$1"/> </operator> <operator activated="true" class="guess_types" compatibility="5.2.008" expanded="true" height="76" name="Guess Types" width="90" x="447" y="300"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="id"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="guess_types" compatibility="5.2.008" expanded="true" height="76" name="Guess Types (2)" width="90" x="447" y="165"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="id"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="join" compatibility="5.2.008" expanded="true" height="76" name="Join" width="90" x="581" y="120"> <list key="key_attributes"/> </operator> <operator activated="true" class="map_clustering_on_labels" compatibility="5.2.008" expanded="true" height="76" name="Map Clustering on Labels" width="90" x="715" y="30"/> <operator activated="true" class="performance" compatibility="5.2.008" expanded="true" height="76" name="Performance" width="90" x="849" y="30"/> <connect from_op="Retrieve" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Clustering" to_port="example set"/> <connect from_op="Select Attributes" from_port="original" to_op="Replace" to_port="example set input"/> <connect from_op="Clustering" from_port="cluster model" to_op="Map Clustering on Labels" to_port="cluster model"/> <connect from_op="Clustering" from_port="clustered set" to_op="Guess Types (2)" to_port="example set input"/> <connect from_op="Replace" from_port="example set output" to_op="Guess Types" to_port="example set input"/> <connect from_op="Guess Types" from_port="example set output" to_op="Join" to_port="right"/> <connect from_op="Guess Types (2)" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="Guess Types (2)" from_port="original" to_port="result 2"/> <connect from_op="Join" from_port="join" to_op="Map Clustering on Labels" to_port="example set"/> <connect from_op="Map Clustering on Labels" from_port="example set" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
