<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process"> <process expanded="true" height="235" width="413"> <operator activated="true" class="generate_data" compatibility="5.3.000" expanded="true" height="60" name="Generate Data" width="90" x="112" y="30"/> <operator activated="true" class="series:data_to_series" compatibility="5.2.001" expanded="true" height="60" name="Data To Series" width="90" x="246" y="30"> <parameter key="series_attribute" value="att1"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Data To Series" to_port="example set"/> <connect from_op="Data To Series" from_port="series" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <process expanded="true" height="394" width="640"> <operator activated="true" class="retrieve" compatibility="5.2.008" expanded="true" height="60" name="Retrieve (3)" width="90" x="45" y="75"> <parameter key="repository_entry" value="../../Results/ResultsParaFFT"/> </operator> <operator activated="true" class="series:data_to_series" compatibility="5.2.000" expanded="true" height="60" name="Data To Series" width="90" x="246" y="75"> <parameter key="transformation_mode" value="series_from_attributes"/> <parameter key="series_attribute" value="AccXC"/> </operator> <operator activated="true" class="series:fast_fourier_transformation" compatibility="5.2.000" expanded="true" height="60" name="Fast Fourier Transformation" width="90" x="380" y="75"/> <operator activated="true" class="series:series_to_data" compatibility="5.2.000" expanded="true" height="60" name="Series To Data" width="90" x="514" y="75"/> <connect from_op="Retrieve (3)" from_port="output" to_op="Data To Series" to_port="example set"/> <connect from_op="Data To Series" from_port="series" to_op="Fast Fourier Transformation" to_port="series"/> <connect from_op="Fast Fourier Transformation" from_port="series" to_op="Series To Data" to_port="series"/> <connect from_op="Series To Data" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
