Operator BayesNet = secondSubProcess.getOperator("W-BayesNet");BayesNet.execute();
<?xml version="1.0"encoding="UTF-8" standalone="no"><process version="5.2.000"><context><input/><output/><macros/></context><operator activated="true" class="dummy" compatibility="5.2.000" expanded="true" name="W-BayesNet"></process>
RapidMiner.setExecutionMode(ExecutionMode.EMBEDDED_WITHOUT_UI);// try ExecutionMode.COMMAND_LINE if that does not workRapidMiner.init();
System.setProperty("Rapidminer.init.weka","true")
RapidMiner.setExecutionMode(ExecutionMode.EMBEDDED_WITHOUT_UI); RapidMiner.init(); ClassLoader loader= weka.classifiers.bayes.BayesNet.class.getClassLoader(); WekaOperatorFactory factory = new WekaOperatorFactory();File wekaFile = new File(pathToWekaJarFile); Plugin plugin = null;try{ plugin = new Plugin(wekaFile); }catch (Exception e){System.out.Println("error");}factory.registerOperators(loader, plugin);
