Hallo,
I invoke RapidMiner in my Java Application like this:
final Random random = new Random();
final Object[][] data = new Object[5][5];
for (int i = 0; i < 5; ++i) {
for (int j = 0; j < 5; ++j) {
if (j == 0) {
data = "label" + random.nextInt();
} else {
data = random.nextInt();
final ExampleSet exampleSet = ExampleSetFactory.createExampleSet(data, 0);
RapidMiner.init();
final File process = new File("file.rmp");
final Process rapidMinerProcess = new Process(process);
final IOContainer ioContainer = rapidMinerProcess.run(new IOContainer(exampleSet));
But I get every time the following exception:
Exception in thread "main" com.rapidminer.operator.UserError: The example set has no examples
at com.rapidminer.example.Tools.isNonEmpty(Tools.java:469)
at com.rapidminer.operator.performance.PolynominalClassificationPerformanceEvaluator.checkCompatibility(PolynominalClassificationPerformanceEvaluator.java:105)
at com.rapidminer.operator.performance.AbstractPerformanceEvaluator.doWork(AbstractPerformanceEvaluator.java:234)
at com.rapidminer.operator.Operator.execute(Operator.java:834)
at com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:51)
at com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:711)
at com.rapidminer.operator.validation.ValidationChain.executeEvaluator(ValidationChain.java:223)
at com.rapidminer.operator.validation.ValidationChain.evaluate(ValidationChain.java:324)
at com.rapidminer.operator.validation.XValidation.performIteration(XValidation.java:162)
at com.rapidminer.operator.validation.XValidation.estimatePerformance(XValidation.java:151)
at com.rapidminer.operator.validation.ValidationChain.doWork(ValidationChain.java:273)
at com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:379)
at com.rapidminer.Process.run(Process.java:925)
at com.rapidminer.Process.run(Process.java:848)
at com.rapidminer.Process.run(Process.java:807)
at com.rapidminer.Process.run(Process.java:802)
My process is stored as XML and looks like this:
<process version="5.2.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
<process expanded="true" height="638" width="165">
<operator activated="true" class="x_validation" compatibility="5.2.008" expanded="true" height="112" name="Validation" width="90" x="45" y="30">
<operator activated="true" class="naive_bayes" compatibility="5.2.008" expanded="true" height="76" name="Naive Bayes" width="90" x="45" y="30"/>
<connect from_port="training" to_op="Naive Bayes" to_port="training set"/>
<connect from_op="Naive Bayes" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<process expanded="true" height="638" width="300">
<operator activated="true" class="apply_model" compatibility="5.2.008" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30">
<operator activated="true" class="performance_classification" compatibility="5.2.008" expanded="true" height="76" name="Performance" width="90" x="180" y="30">
<list key="class_weights"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<connect from_port="input 1" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="averagable 1" to_port="result 1"/>
</process>
</process>
Does anyone have an idea what's my mistake?
Thanks in advance.
Cornelius
