I have a list of messages and I am trying to determine which go together to analyze later. I am trying to group them using X-Means after creating a binomial word vector and I get an error during run time: SEVERE: java.lang.ArrayIndexOutOfBoundsException: 237. Is there something I am not doing to the examples input before I am passing it to the X-Means block?
<process version="5.2.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
<parameter key="logverbosity" value="all"/>
<parameter key="logfile" value="C:\LogToolsGUI\MachineLearning\LogMessages.log"/>
<parameter key="resultfile" value="C:\LogToolsGUI\MachineLearning\MessageResults.res"/>
<process expanded="true" height="566" width="815">
<operator activated="true" class="read_csv" compatibility="5.2.008" expanded="true" height="60" name="Read CSV" width="90" x="112" y="75">
<parameter key="csv_file" value="C:\LogToolsGUI\TestSet.csv"/>
<parameter key="column_separators" value=","/>
<parameter key="skip_comments" value="true"/>
<parameter key="parse_numbers" value="false"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations"/>
<parameter key="encoding" value="windows-1252"/>
<parameter key="0" value="att1.false.polynominal.attribute"/>
<parameter key="1" value="att2.true.text.attribute"/>
</list>
<operator activated="true" class="text:process_document_from_data" compatibility="5.2.004" expanded="true" height="76" name="Process Documents from Data" width="90" x="112" y="165">
<parameter key="vector_creation" value="Term Occurrences"/>
<parameter key="add_meta_information" value="false"/>
<parameter key="keep_text" value="true"/>
<parameter key="prune_method" value="absolute"/>
<parameter key="prune_below_absolute" value="5"/>
<parameter key="prune_above_absolute" value="9999"/>
<list key="specify_weights"/>
<process expanded="true" height="686" width="802">
<operator activated="true" class="text:tokenize" compatibility="5.2.004" expanded="true" height="60" name="Tokenize" width="90" x="45" y="30"/>
<operator activated="true" class="text:transform_cases" compatibility="5.2.004" expanded="true" height="60" name="Transform Cases" width="90" x="45" y="120"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="5.2.004" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="45" y="210"/>
<operator activated="true" class="text:filter_by_length" compatibility="5.2.004" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="246" y="210">
<parameter key="min_chars" value="2"/>
<operator activated="false" class="text:generate_n_grams_terms" compatibility="5.2.004" expanded="true" height="60" name="Generate n-Grams (Terms)" width="90" x="246" y="120"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Stopwords (English)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="x_means" compatibility="5.2.008" expanded="true" height="76" name="X-Means" width="90" x="380" y="165"/>
<connect from_op="Read CSV" from_port="output" to_op="Process Documents from Data" to_port="example set"/>
<connect from_op="Process Documents from Data" from_port="example set" to_op="X-Means" to_port="example set"/>
<connect from_op="X-Means" from_port="cluster model" to_port="result 1"/>
<connect from_op="X-Means" from_port="clustered set" to_port="result 2"/>
</process>
</process>
EDIT: I shrank the input size down to 300 rows and it started running. Any larger and it would fail.
