Marcin wrote:If your five datasets are equal-sized that should work.
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process"> <process expanded="true" height="550" width="815"> <operator activated="true" class="retrieve" compatibility="5.3.000" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="retrieve" compatibility="5.3.000" expanded="true" height="60" name="Retrieve (2)" width="90" x="45" y="120"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="retrieve" compatibility="5.3.000" expanded="true" height="60" name="Retrieve (3)" width="90" x="45" y="210"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="retrieve" compatibility="5.3.000" expanded="true" height="60" name="Retrieve (4)" width="90" x="45" y="300"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="retrieve" compatibility="5.3.000" expanded="true" height="60" name="Retrieve (5)" width="90" x="45" y="390"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="subprocess" compatibility="5.3.000" expanded="true" height="148" name="Append with set_id" width="90" x="246" y="30"> <process expanded="true" height="538" width="893"> <operator activated="true" class="generate_attributes" compatibility="5.3.000" expanded="true" height="76" name="Generate Attributes" width="90" x="45" y="30"> <list key="function_descriptions"> <parameter key="set_id" value="1"/> </list> </operator> <operator activated="true" class="generate_attributes" compatibility="5.3.000" expanded="true" height="76" name="Generate Attributes (2)" width="90" x="45" y="120"> <list key="function_descriptions"> <parameter key="set_id" value="2"/> </list> </operator> <operator activated="true" class="generate_attributes" compatibility="5.3.000" expanded="true" height="76" name="Generate Attributes (3)" width="90" x="45" y="210"> <list key="function_descriptions"> <parameter key="set_id" value="3"/> </list> </operator> <operator activated="true" class="generate_attributes" compatibility="5.3.000" expanded="true" height="76" name="Generate Attributes (4)" width="90" x="45" y="300"> <list key="function_descriptions"> <parameter key="set_id" value="4"/> </list> </operator> <operator activated="true" class="generate_attributes" compatibility="5.3.000" expanded="true" height="76" name="Generate Attributes (5)" width="90" x="45" y="390"> <list key="function_descriptions"> <parameter key="set_id" value="5"/> </list> </operator> <operator activated="true" class="append" compatibility="5.3.000" expanded="true" height="148" name="Append (2)" width="90" x="246" y="30"/> <operator activated="true" class="set_role" compatibility="5.3.000" expanded="true" height="76" name="Set Role" width="90" x="447" y="30"> <parameter key="name" value="set_id"/> <parameter key="target_role" value="set"/> <list key="set_additional_roles"/> </operator> <connect from_port="in 1" to_op="Generate Attributes" to_port="example set input"/> <connect from_port="in 2" to_op="Generate Attributes (2)" to_port="example set input"/> <connect from_port="in 3" to_op="Generate Attributes (3)" to_port="example set input"/> <connect from_port="in 4" to_op="Generate Attributes (4)" to_port="example set input"/> <connect from_port="in 5" to_op="Generate Attributes (5)" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Append (2)" to_port="example set 1"/> <connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Append (2)" to_port="example set 2"/> <connect from_op="Generate Attributes (3)" from_port="example set output" to_op="Append (2)" to_port="example set 3"/> <connect from_op="Generate Attributes (4)" from_port="example set output" to_op="Append (2)" to_port="example set 4"/> <connect from_op="Generate Attributes (5)" from_port="example set output" to_op="Append (2)" to_port="example set 5"/> <connect from_op="Append (2)" from_port="merged set" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="source_in 3" spacing="0"/> <portSpacing port="source_in 4" spacing="0"/> <portSpacing port="source_in 5" spacing="0"/> <portSpacing port="source_in 6" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="loop" compatibility="5.3.000" expanded="true" height="76" name="Loop" width="90" x="380" y="30"> <parameter key="set_iteration_macro" value="true"/> <parameter key="macro_name" value="k"/> <parameter key="iterations" value="5"/> <process expanded="true" height="538" width="893"> <operator activated="true" class="filter_examples" compatibility="5.3.000" expanded="true" height="76" name="Get Train" width="90" x="45" y="30"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="set_id=%{k}"/> <parameter key="invert_filter" value="true"/> </operator> <operator activated="true" class="naive_bayes" compatibility="5.3.000" expanded="true" height="76" name="Naive Bayes" width="90" x="313" y="30"/> <operator activated="true" class="filter_examples" compatibility="5.3.000" expanded="true" height="76" name="Get Test" width="90" x="179" y="165"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="set_id=%{k}"/> </operator> <operator activated="true" class="apply_model" compatibility="5.3.000" expanded="true" height="76" name="Apply Model" width="90" x="447" y="120"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.3.000" expanded="true" height="76" name="Performance" width="90" x="581" y="120"/> <connect from_port="input 1" to_op="Get Train" to_port="example set input"/> <connect from_op="Get Train" from_port="example set output" to_op="Naive Bayes" to_port="training set"/> <connect from_op="Get Train" from_port="original" to_op="Get Test" to_port="example set input"/> <connect from_op="Naive Bayes" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Get Test" from_port="example set output" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="average" compatibility="5.3.000" expanded="true" height="76" name="Average" width="90" x="514" y="30"/> <connect from_op="Retrieve" from_port="output" to_op="Append with set_id" to_port="in 1"/> <connect from_op="Retrieve (2)" from_port="output" to_op="Append with set_id" to_port="in 2"/> <connect from_op="Retrieve (3)" from_port="output" to_op="Append with set_id" to_port="in 3"/> <connect from_op="Retrieve (4)" from_port="output" to_op="Append with set_id" to_port="in 4"/> <connect from_op="Retrieve (5)" from_port="output" to_op="Append with set_id" to_port="in 5"/> <connect from_op="Append with set_id" from_port="out 1" to_op="Loop" to_port="input 1"/> <connect from_op="Loop" from_port="output 1" to_op="Average" to_port="averagable 1"/> <connect from_op="Average" from_port="average" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
