I would like to use precomputed kernel matrix in my experiment, because I need use chi square kernel. My questions:
1.) When I pick precomputed kernel in LibSVM, I don't know, how I insert precomputed kernel matrix into SVM.
2.) Format of file with precomputed kernel.
This is my experiment:
<process version="5.0">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.0.10" expanded="true" name="Process">
<process expanded="true" height="400" width="681">
<operator activated="true" class="read_sparse" compatibility="5.0.10" expanded="true" height="60" name="Read Sparse" width="90" x="45" y="75">
<parameter key="format" value="yx"/>
<parameter key="data_file" value="D:\Praca\DataSet\trainDataSet.txt"/>
<parameter key="dimension" value="16"/>
<parameter key="use_quotes" value="false"/>
<list key="prefix_map"/>
<operator activated="true" class="optimize_parameters_grid" compatibility="5.0.10" expanded="true" height="112" name="Optimize Parameters (Grid)" width="90" x="179" y="75">
<list key="parameters">
<parameter key="SVM.C" value="[0.1;5000;3;logarithmic]"/>
<parameter key="SVM.gamma" value="[0.00001;100;3;logarithmic]"/>
</list>
<process expanded="true" height="400" width="677">
<operator activated="true" class="x_validation" compatibility="5.0.10" expanded="true" height="112" name="Validation" width="90" x="179" y="30">
<parameter key="number_of_validations" value="6"/>
<process expanded="true" height="400" width="313">
<operator activated="true" class="support_vector_machine_libsvm" compatibility="5.0.10" expanded="true" height="76" name="SVM" width="90" x="112" y="30">
<parameter key="kernel_type" value="precomputed"/>
<parameter key="gamma" value="100.00000000000001"/>
<parameter key="C" value="5000.0"/>
<parameter key="cache_size" value="800"/>
<list key="class_weights">
<parameter key="0" value="0.6088239"/>
<parameter key="1" value="0.3911761"/>
</list>
<connect from_port="training" to_op="SVM" to_port="training set"/>
<connect from_op="SVM" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="5.0.10" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30">
<operator activated="true" class="performance" compatibility="5.0.10" expanded="true" height="76" name="Performance" width="90" x="179" y="30"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<operator activated="true" class="log" compatibility="5.0.10" expanded="true" height="76" name="Log" width="90" x="380" y="165">
<list key="log"/>
<connect from_port="input 1" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="model" to_port="result 1"/>
<connect from_op="Validation" from_port="averagable 1" to_op="Log" to_port="through 1"/>
<connect from_op="Log" from_port="through 1" to_port="performance"/>
<portSpacing port="sink_performance" spacing="0"/>
</process>
<operator activated="true" class="read_sparse" compatibility="5.0.10" expanded="true" height="60" name="Read Sparse (2)" width="90" x="45" y="255">
<parameter key="data_file" value="D:\Praca\DataSet\testDataSet.txt"/>
<operator activated="true" class="apply_model" compatibility="5.0.10" expanded="true" height="76" name="Apply Model (2)" width="90" x="380" y="210">
<operator activated="true" class="performance" compatibility="5.0.10" expanded="true" height="76" name="Performance (2)" width="90" x="514" y="165"/>
<connect from_op="Read Sparse" from_port="output" to_op="Optimize Parameters (Grid)" to_port="input 1"/>
<connect from_op="Optimize Parameters (Grid)" from_port="performance" to_port="result 1"/>
<connect from_op="Optimize Parameters (Grid)" from_port="parameter" to_port="result 2"/>
<connect from_op="Optimize Parameters (Grid)" from_port="result 1" to_op="Apply Model (2)" to_port="model"/>
<connect from_op="Read Sparse (2)" from_port="output" to_op="Apply Model (2)" to_port="unlabelled data"/>
<connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/>
<connect from_op="Performance (2)" from_port="performance" to_port="result 3"/>
</process>
</process>
Thank you.
