<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.009"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.009" expanded="true" name="Process"> <process expanded="true" height="420" width="706"> <operator activated="true" class="set_macro" compatibility="5.2.009" expanded="true" height="76" name="Set Macro A" width="90" x="45" y="30"> <parameter key="macro" value="A"/> <parameter key="value" value="abcd"/> </operator> <operator activated="true" class="set_macro" compatibility="5.2.009" expanded="true" height="76" name="Set Macro B" width="90" x="179" y="30"> <parameter key="macro" value="B"/> <parameter key="value" value="a#1d"/> </operator> <operator activated="true" class="generate_macro" compatibility="5.2.009" expanded="true" height="76" name="Parse B" width="90" x="313" y="30"> <list key="function_descriptions"> <parameter key="B_parsed" value="replace("%{B}", "#1", "(.*)")"/> </list> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.2.009" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="45" y="165"> <list key="attribute_values"> <parameter key="A" value=""%{A}""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="replace" compatibility="5.2.009" expanded="true" height="76" name="Replace" width="90" x="179" y="165"> <parameter key="replace_what" value="%{B_parsed}"/> <parameter key="replace_by" value="$1"/> </operator> <connect from_op="Set Macro A" from_port="through 1" to_op="Set Macro B" to_port="through 1"/> <connect from_op="Set Macro B" from_port="through 1" to_op="Parse B" to_port="through 1"/> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Replace" to_port="example set input"/> <connect from_op="Replace" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="126"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
