How to move a process running on local windows to a linux machine
tryingRM
I designed a process to load data and run a NN model on local windows machine for a small data set. Now wanted to move the process to run on a remote linux machine on a much larger data set. What files need to copied to linux box in order to run there on commandline batch mode without GUI? (GUI is way too slow on the x-window so duplicating the process using GUI design is not an option). Both RM version is 5.2.
Thanks,
KV
MacOS
Linux + variants
frito
hi
1.process file is in ur repository "ProcessName.rmp" or you can export it as XML. I personally move rmp files directly from my repository.
2. running without gui has been discussed here recently and a short howto is there as well.
e.g.:
http://rapid-i.com/rapidforum/index.php/topic,5064.msg18225.html#msg18225
Nils_Woehler
I would recommend you to install RapidAnalytics Community Editon on the linux machine.
This gives you the ability to run the process remotely without copying a file.
Best,
Nils
