Hi RM community,
I was looking for a way to get the correlation value out of the correlation matrix. As this doesn't seem to be feasible (in the community version without reports as described in the forum) I tried to capture correlation from the "performance (regression)" operator.
I discovered that the performance operator delivers 0.000 as correlation in case that correlation is negative.
To reproduce this behaviour run the attached process. Look at the result of the correlation matrix. "att1" and "att" have a negative correlation to "label".
Then change the "name" parameter of the "set role 2" operator to an arbitrary attribute and compare the result of the performance operator to the correlation matrix.
In case that "att1" or "att5" is being selected the performance operator will show 0.000
<process version="5.2.003">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.0.000" expanded="true" name="Root">
<process expanded="true" height="494" width="567">
<operator activated="true" class="generate_data" compatibility="5.2.003" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/>
<operator activated="true" class="multiply" compatibility="5.2.003" expanded="true" height="94" name="Multiply" width="90" x="179" y="30"/>
<operator activated="true" class="set_role" compatibility="5.2.003" expanded="true" height="76" name="Set Role" width="90" x="313" y="165">
<parameter key="name" value="label"/>
<operator activated="true" class="correlation_matrix" compatibility="5.2.003" expanded="true" height="94" name="Correlation Matrix" width="90" x="447" y="165"/>
<operator activated="true" class="set_role" compatibility="5.2.003" expanded="true" height="76" name="Set Role (2)" width="90" x="313" y="30">
<parameter key="name" value="att2"/>
<parameter key="target_role" value="prediction"/>
<operator activated="true" class="performance_regression" compatibility="5.2.003" expanded="true" height="76" name="Performance" width="90" x="447" y="30">
<parameter key="main_criterion" value="correlation"/>
<parameter key="root_mean_squared_error" value="false"/>
<parameter key="correlation" value="true"/>
<parameter key="skip_undefined_labels" value="false"/>
<parameter key="use_example_weights" value="false"/>
<connect from_op="Generate Data" from_port="output" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Set Role (2)" to_port="example set input"/>
<connect from_op="Multiply" from_port="output 2" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Correlation Matrix" to_port="example set"/>
<connect from_op="Correlation Matrix" from_port="matrix" to_port="result 2"/>
<connect from_op="Correlation Matrix" from_port="weights" to_port="result 3"/>
<connect from_op="Set Role (2)" from_port="example set output" to_op="Performance" to_port="labelled data"/>
<connect from_op="Performance" from_port="performance" to_port="result 1"/>
<portSpacing port="sink_result 2" spacing="144"/>
</process>
</process>
Kind regards
Sachs
