Hi there,
I am (unfortunately) not an expert in correlations calculation but the result of this sample process seems strange to me.
First I run the code as is. --> Result includes all attributes
Then I change the parameter "filter relation" to property "less". --> Result still includes att1
To my understanding att1 can either have a correlation greater than 0.9 OR less than 0.9 but it cannot appear in both results...
<process version="5.2.003">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.0.000" expanded="true" name="Root">
<process expanded="true" height="512" width="640">
<operator activated="true" class="generate_data" compatibility="5.2.003" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/>
<operator activated="true" class="remove_correlated_attributes" compatibility="5.2.003" expanded="true" height="76" name="Remove Correlated Attributes" width="90" x="179" y="30">
<parameter key="correlation" value="0.9"/>
<connect from_op="Generate Data" from_port="output" to_op="Remove Correlated Attributes" to_port="example set input"/>
<connect from_op="Remove Correlated Attributes" from_port="example set output" to_port="result 1"/>
</process>
</process>
Best regards
Sachs
