I do exercise OS-T 3030. When I finish, I don't have optimization results (_des.h3d files). Can you explain this issue to me?
Best regards,
Tuan.
Hi Pham,Have you done the tutorial and then run the model?If yes, please share the file.Please take a look at the file attached. The panel_des.h3d is showing the iterations correctly.Please consider marking the answer as correct if it works for you otherwise, let me know how I can help you.Thank you,
Hi Robinson,
I attached this file, where I did the tutorial and then run the model. Can you check it for me?
Thanks,
