Dear all,
I thought the correlation matrix would provide weights according the attributes' capabilities to describe the label. However, I can even run the correlation without a label. But how to interpret the weights then?
<process version="5.2.003">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process">
<process expanded="true" height="447" width="413">
<operator activated="true" class="generate_data" compatibility="5.2.003" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/>
<operator activated="true" class="select_attributes" compatibility="5.2.003" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="30">
<parameter key="attribute" value="label"/>
<operator activated="true" class="correlation_matrix" compatibility="5.2.003" expanded="true" height="94" name="Correlation Matrix" width="90" x="313" y="30"/>
<connect from_op="Generate Data" from_port="output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Correlation Matrix" to_port="example set"/>
<connect from_op="Correlation Matrix" from_port="weights" to_port="result 1"/>
</process>
</process>
Furthermore, I'm thought that there might be correlations that are shifted in time (timelag). Do you have a good approach to figure this out?
My first idea is to take an optimization parameter that varies the horizon of a windowing operator. For each run the correlation matrix is applied. In the end I take horizon that offers the best correlation.
That should work but it appears to be a little complicated and I'm curious whether there is a better way to do this.
All the best
Sachs
