<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.000" expanded="true" name="Process"> <process expanded="true" height="626" width="1016"> <operator activated="true" class="retrieve" compatibility="5.2.000" expanded="true" height="60" name="Retrieve" width="90" x="45" y="120"> <parameter key="repository_entry" value="datasetfordatamining"/> </operator> <operator activated="true" class="set_role" compatibility="5.2.000" expanded="true" height="76" name="Set Role" width="90" x="246" y="75"> <parameter key="name" value="label"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="x_validation" compatibility="5.1.002" expanded="true" height="112" name="Validation" width="90" x="380" y="30"> <description>A cross-validation evaluating a linear regression model.</description> <parameter key="leave_one_out" value="true"/> <process expanded="true" height="654" width="480"> <operator activated="true" class="multiply" compatibility="5.2.000" expanded="true" height="94" name="Multiply" width="90" x="49" y="43"/> <operator activated="true" class="naive_bayes_kernel" compatibility="5.2.000" expanded="true" height="76" name="Naive Bayes (Kernel)" width="90" x="112" y="165"/> <operator activated="true" class="support_vector_machine" compatibility="5.2.000" expanded="true" height="112" name="SVM" width="90" x="188" y="39"> <parameter key="kernel_cache" value="300"/> <parameter key="C" value="1.0"/> <parameter key="max_iterations" value="10000"/> <parameter key="balance_cost" value="true"/> <parameter key="quadratic_loss_pos" value="true"/> <parameter key="quadratic_loss_neg" value="true"/> </operator> <operator activated="true" class="group_models" compatibility="5.2.000" expanded="true" height="94" name="Group Models (2)" width="90" x="313" y="120"/> <connect from_port="training" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="SVM" to_port="training set"/> <connect from_op="Multiply" from_port="output 2" to_op="Naive Bayes (Kernel)" to_port="training set"/> <connect from_op="Naive Bayes (Kernel)" from_port="model" to_op="Group Models (2)" to_port="models in 2"/> <connect from_op="SVM" from_port="model" to_op="Group Models (2)" to_port="models in 1"/> <connect from_op="Group Models (2)" from_port="model out" to_port="model"/> <portSpacing port="source_training" spacing="18"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="654" width="466"> <operator activated="true" class="apply_model" compatibility="5.2.000" expanded="true" height="76" name="Apply Model" width="90" x="112" y="75"> <list key="application_parameters"/> <parameter key="create_view" value="true"/> </operator> <operator activated="true" class="write_model" compatibility="5.2.000" expanded="true" height="60" name="Write Model" width="90" x="246" y="255"> <parameter key="model_file" value="C:\Users\Lenka\Documents\RapidMinerRepository\modelfile"/> </operator> <operator activated="true" class="performance" compatibility="5.2.000" expanded="true" height="76" name="Performance" width="90" x="246" y="75"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Apply Model" from_port="model" to_op="Write Model" to_port="input"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="36"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="90"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_op="Retrieve" from_port="output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="model" to_port="result 2"/> <connect from_op="Validation" from_port="training" to_port="result 3"/> <connect from_op="Validation" from_port="averagable 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process>
