issues of installing R-extension
I followed the R-extension installation guide step-by-step, except the following step,
“Now you can configure RapidMiner. If you click on Next, you will be asked to enter the path to the jri library that has been installed with rJava. This is located in one of the .libpath directories noted above and more exact in <libpath directory>/rJava/jri/. The filename depends on your operating system and is jri.dll on Windows and libjri.so or jri.so on Unix.”
After clicking next, I selected C:\users\suc\Documents\R\win-library\2.15\rJava\jri\jri.dll
I think it should have been C:\users\suc\Documents\R\win-library\2.15\rJava\jri\jri.dll
But looks like there is no way to allow me modify it. I tried to re-install RapidMiner, removing R-extension and re-install R-extension. No matter what I did, it seems that the system just remember this. After I click next, the popup message box always says: Found library in C:\users\suc\Documents\R\win-library\2.15\rJava\jri\jri.dll
