I'm developing an app which uses RapidMiner for classification. I train the classifier time to time (e.g. daily) but I use the classifier in very high rate (250 per sec).
For this purpose, I created two Processes using RM GUI. First one trains the classifier and saves it into a model file while the second one uses it for classification.
In the second process I load the model file which the first process creates. This made it very slow since it seems that the process loads it every time I want to classify an input.
You can see the second process in the following picture:
What's the more smart way of doing this?
P.S. I think a solution is to create another process which only loads the created classifier only once and then give it to ApplyModel subprocess as another input. But I didn't find a solution for doing so in Java code.
