[Solved] Error in Generate Attributes operator
qwertz
Dear community,
When using function "param()" of the type "process" in "generate attributes" operator I receive an error:
"unrecocnized symbol "param" encountered"
I also tried the example given in the parameter's help: "param("Read Excel", "file") --> same error
Does anyone encountered the same problem?
Cheers
Sachs
Errors
Generate Attributes
MariusHelf
Hi Sachs,
just be a bit more courageous on hitting the play button, even if RapidMiner complains
This is only a bug in the function editor, but if you run the process, it will work.
I created a bug for this, where you can track the progress on this issue:
http://bugs.rapid-i.com/show_bug.cgi?id=1192
Best, Marius
qwertz
Hi Marius,
thanks for sharing that information. It inspired me to fool around a little and after quite a long time I found out that
- param() function is case sensitive (e.g. param("Generate Data", "datamanagement"))
- parameters consisting of two words need to be written together with underscore (e.g. param("Windowing", "label_attribute"))
Hope this helps a little.
Regards
Sachs
MariusHelf
Yeah, basically everything in RapidMiner is case sensitive: macro names, attribute names, and also operator names.
The underscore thingy is admittedly a bit tricky if you don't know about it. The cause for that is that internally parameter names can't contain spaces and use underscores instead. On screen they are replaced with whitespace for readabilty.
