<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process"> <process expanded="true" height="476" width="882"> <operator activated="true" class="retrieve" compatibility="5.2.006" expanded="true" height="60" name="Retrieve (2)" width="90" x="45" y="210"> <parameter key="repository_entry" value="//Clases/Datos/batch"/> </operator> <operator activated="true" class="multiply" compatibility="5.2.006" expanded="true" height="94" name="Multiply" width="90" x="45" y="30"/> <operator activated="true" class="filter_examples" compatibility="5.2.006" expanded="true" height="76" name="Filter Examples" width="90" x="246" y="30"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="pair1 = training"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.2.006" expanded="true" height="76" name="Select Attributes" width="90" x="380" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|income"/> </operator> <operator activated="true" class="linear_regression" compatibility="5.2.006" expanded="true" height="94" name="Linear Regression" width="90" x="514" y="30"> <parameter key="feature_selection" value="none"/> </operator> <operator activated="true" class="filter_examples" compatibility="5.2.006" expanded="true" height="76" name="Filter Examples (2)" width="90" x="246" y="165"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="pair1 = testing"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.2.006" expanded="true" height="76" name="Select Attributes (2)" width="90" x="380" y="165"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|income"/> </operator> <operator activated="true" class="apply_model" compatibility="5.2.006" expanded="true" height="76" name="Apply Model" width="90" x="581" y="165"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.2.006" expanded="true" height="76" name="Performance" width="90" x="733" y="162"/> <connect from_op="Retrieve (2)" from_port="output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Multiply" from_port="output 2" to_op="Filter Examples (2)" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Linear Regression" to_port="training set"/> <connect from_op="Linear Regression" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Filter Examples (2)" from_port="example set output" to_op="Select Attributes (2)" to_port="example set input"/> <connect from_op="Select Attributes (2)" from_port="example set output" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="126"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process"> <process expanded="true" height="476" width="1016"> <operator activated="true" class="retrieve" compatibility="5.2.006" expanded="true" height="60" name="Retrieve" width="90" x="112" y="75"> <parameter key="repository_entry" value="//Clases/Datos/batch"/> </operator> <operator activated="true" class="loop" compatibility="5.2.006" expanded="true" height="76" name="Loop" width="90" x="313" y="75"> <parameter key="set_iteration_macro" value="true"/> <parameter key="iterations" value="2"/> <process expanded="true" height="740" width="969"> <operator activated="true" class="multiply" compatibility="5.2.006" expanded="true" height="94" name="Multiply (2)" width="90" x="112" y="165"/> <operator activated="true" class="filter_examples" compatibility="5.2.006" expanded="true" height="76" name="Filter Examples (3)" width="90" x="246" y="30"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="pair%{iteration} = training"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.2.006" expanded="true" height="76" name="Select Attributes (3)" width="90" x="380" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|income"/> </operator> <operator activated="true" class="linear_regression" compatibility="5.2.006" expanded="true" height="94" name="Linear Regression (2)" width="90" x="514" y="30"> <parameter key="feature_selection" value="none"/> </operator> <operator activated="true" class="filter_examples" compatibility="5.2.006" expanded="true" height="76" name="Filter Examples (4)" width="90" x="313" y="300"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="pair%{iteration} = testing"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.2.006" expanded="true" height="76" name="Select Attributes (4)" width="90" x="447" y="255"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="income|"/> </operator> <operator activated="true" class="apply_model" compatibility="5.2.006" expanded="true" height="76" name="Apply Model (2)" width="90" x="648" y="210"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.2.006" expanded="true" height="76" name="Performance (2)" width="90" x="782" y="210"/> <connect from_port="input 1" to_op="Multiply (2)" to_port="input"/> <connect from_op="Multiply (2)" from_port="output 1" to_op="Filter Examples (3)" to_port="example set input"/> <connect from_op="Multiply (2)" from_port="output 2" to_op="Filter Examples (4)" to_port="example set input"/> <connect from_op="Filter Examples (3)" from_port="example set output" to_op="Select Attributes (3)" to_port="example set input"/> <connect from_op="Select Attributes (3)" from_port="example set output" to_op="Linear Regression (2)" to_port="training set"/> <connect from_op="Linear Regression (2)" from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_op="Filter Examples (4)" from_port="example set output" to_op="Select Attributes (4)" to_port="example set input"/> <connect from_op="Select Attributes (4)" from_port="example set output" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Performance (2)" from_port="performance" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_op="Retrieve" from_port="output" to_op="Loop" to_port="input 1"/> <connect from_op="Loop" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="126"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
