<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process"> <process expanded="true" height="658" width="727"> <operator activated="true" class="generate_data_user_specification" compatibility="5.2.006" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="112" y="30"> <list key="attribute_values"> <parameter key="comment" value=""example text with AFG346GJA57AW1 serial number""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="nominal_to_text" compatibility="5.2.006" expanded="true" height="76" name="Nominal to Text" width="90" x="246" y="30"/> <operator activated="true" class="text:process_document_from_data" compatibility="5.2.002" expanded="true" height="76" name="Process Documents from Data" width="90" x="447" y="30"> <list key="specify_weights"/> <process expanded="true" height="676" width="727"> <operator activated="true" class="text:extract_information" compatibility="5.2.002" expanded="true" height="60" name="Extract Information" width="90" x="246" y="30"> <parameter key="query_type" value="Regular Expression"/> <list key="string_machting_queries"/> <list key="regular_expression_queries"> <parameter key="serial" value="\s([A-Z0-9]{14})\s"/> </list> <list key="regular_region_queries"/> <list key="xpath_queries"/> <list key="namespaces"/> <list key="index_queries"/> </operator> <connect from_port="document" to_op="Extract Information" to_port="document"/> <connect from_op="Extract Information" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Nominal to Text" to_port="example set input"/> <connect from_op="Nominal to Text" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/> <connect from_op="Process Documents from Data" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process"> <process expanded="true" height="658" width="681"> <operator activated="true" class="generate_data_user_specification" compatibility="5.2.006" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="45" y="75"> <list key="attribute_values"> <parameter key="comment" value=""example text with AFG346GJA57AW1 serial number""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.2.006" expanded="true" height="60" name="Generate Data by User Specification (2)" width="90" x="45" y="165"> <list key="attribute_values"> <parameter key="comment" value=""bla bla AFGASDFGA57AW1 hrznfrz""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="append" compatibility="5.2.006" expanded="true" height="94" name="Append" width="90" x="179" y="75"/> <operator activated="true" class="generate_id" compatibility="5.2.006" expanded="true" height="76" name="Generate ID" width="90" x="313" y="75"/> <operator activated="true" class="nominal_to_text" compatibility="5.2.006" expanded="true" height="76" name="Nominal to Text" width="90" x="447" y="75"/> <operator activated="true" class="multiply" compatibility="5.2.006" expanded="true" height="94" name="Multiply" width="90" x="45" y="345"/> <operator activated="true" class="text:process_document_from_data" compatibility="5.2.002" expanded="true" height="76" name="Process Documents from Data" width="90" x="179" y="435"> <list key="specify_weights"/> <process expanded="true" height="676" width="727"> <operator activated="true" class="text:extract_information" compatibility="5.2.002" expanded="true" height="60" name="Extract Information" width="90" x="179" y="30"> <parameter key="query_type" value="Regular Expression"/> <list key="string_machting_queries"/> <list key="regular_expression_queries"> <parameter key="serial" value="\s([A-Z0-9]{14})\s"/> </list> <list key="regular_region_queries"/> <list key="xpath_queries"/> <list key="namespaces"/> <list key="index_queries"/> </operator> <connect from_port="document" to_op="Extract Information" to_port="document"/> <connect from_op="Extract Information" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="select_attributes" compatibility="5.2.006" expanded="true" height="76" name="Select Attributes" width="90" x="313" y="435"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="serial"/> </operator> <operator activated="true" class="join" compatibility="5.2.006" expanded="true" height="76" name="Join" width="90" x="447" y="345"> <list key="key_attributes"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.2.006" expanded="true" height="76" name="Select Attributes (2)" width="90" x="581" y="345"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="id"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="true"/> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Append" to_port="example set 1"/> <connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Append" to_port="example set 2"/> <connect from_op="Append" from_port="merged set" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Nominal to Text" to_port="example set input"/> <connect from_op="Nominal to Text" from_port="example set output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Join" to_port="left"/> <connect from_op="Multiply" from_port="output 2" to_op="Process Documents from Data" to_port="example set"/> <connect from_op="Process Documents from Data" from_port="example set" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Join" to_port="right"/> <connect from_op="Join" from_port="join" to_op="Select Attributes (2)" to_port="example set input"/> <connect from_op="Select Attributes (2)" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="306"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
