[SOLVED] Help Needed in tokenization
gunjanamit
I have an excel which has some comments written in each cell on A column.
I want to extract all the words and find word frequency.
My XML is
<process version="5.2.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.001" expanded="true" name="Process">
<process expanded="true" height="251" width="413">
<operator activated="true" class="read_excel" compatibility="5.2.001" expanded="true" height="60" name="Read Excel" width="90" x="59" y="101">
<parameter key="excel_file" value="C:\Users\guagg\Desktop\HP\samp.xls"/>
<parameter key="imported_cell_range" value="A1:A30"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<list key="data_set_meta_data_information"/>
<operator activated="true" class="text:process_document_from_data" compatibility="5.2.002" expanded="true" height="76" name="Process Documents from Data" width="90" x="246" y="120">
<parameter key="prune_method" value="absolute"/>
<parameter key="prune_below_absolute" value="2"/>
<parameter key="prune_above_absolute" value="9999"/>
<list key="specify_weights"/>
<process expanded="true" height="414" width="762">
<operator activated="true" class="text:tokenize" compatibility="5.2.002" expanded="true" height="60" name="Tokenize" width="90" x="124" y="28">
<parameter key="characters" value=" "/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_port="document 1"/>
</process>
<connect from_op="Read Excel" from_port="output" to_op="Process Documents from Data" to_port="example set"/>
<connect from_op="Process Documents from Data" from_port="example set" to_port="result 1"/>
<connect from_op="Process Documents from Data" from_port="word list" to_port="result 2"/>
</process>
</process>
But its not working. Can someone help please?
Rene
Under "Problems" Rapid Miner tells you that "he example set must contain at least one text attribute."
So ...
adding a "Nominal to Text" operator between "Read Excel" and "Process Docs from Data"
and selecting the corresponding column OR
directly declaring your desired column as type=text instead
of type=polynominal within the import process
... might work.
Here's a demo video:
http://www.youtube.com/watch?v=3Kntxr16EwE
gunjanamit
Awesome Rene.....
It works....
Thanks a lot for your help!!!!!!!!!!
Could you please share your email ID with me.
