Good Day all.
I try to preprocessing text from CSV file to .txt file. However, I couldn't get the output written in the .txt file. If it does, it only rewrites the input file.
However, the good thing is I could get the output at the stdout for logging results.
Here I attach my XML code.
<?xml version="1.0" encoding="UTF-8" standalone="no"?> <process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process"> <parameter key="logverbosity" value="status"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true" height="370" width="820"> <operator activated="true" class="text:read_document" compatibility="5.2.002" expanded="true" height="60" name="Read Document" width="90" x="45" y="30"> <parameter key="file" value="C:\Users\user\Desktop\product2e.csv"/> <parameter key="extract_text_only" value="true"/> <parameter key="use_file_extension_as_type" value="true"/> <parameter key="content_type" value="txt"/> <parameter key="encoding" value="SYSTEM"/> </operator> <operator activated="true" class="text:tokenize" compatibility="5.2.002" expanded="true" height="60" name="Tokenize" width="90" x="45" y="120"> <parameter key="mode" value="non letters"/> <parameter key="characters" value=".:"/> <parameter key="language" value="English"/> <parameter key="max_token_length" value="3"/> </operator> <operator activated="true" class="text:transform_cases" compatibility="5.2.002" expanded="true" height="60" name="Transform Cases" width="90" x="179" y="120"> <parameter key="transform_to" value="lower case"/> </operator> <operator activated="true" class="text:filter_stopwords_english" compatibility="5.2.002" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="313" y="120"/> <operator activated="true" class="write_as_text" compatibility="5.2.006" expanded="true" height="76" name="Write as Text" width="90" x="581" y="120"> <parameter key="result_file" value="C:\Users\user\Desktop\result1.txt"/> <parameter key="encoding" value="SYSTEM"/> </operator> <connect from_op="Read Document" from_port="output" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/> <connect from_op="Transform Cases" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/> <connect from_op="Filter Stopwords (English)" from_port="document" to_op="Write as Text" to_port="input 1"/> <connect from_op="Write as Text" from_port="input 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="234"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
and one more thing is how am I going to write the output line by line? At the stdout, it writes all the words together without separate.
Thanks all.
Fizah.
