text mining filter stopwords (dictionary)
User: "kulturevulture"
New Altair Community Member
Updated by Jocelyn
Hello. I have a process to read an Excel file, process documents from data, and create correlation matrix. The process runs fine except when I want to add a filter stopwords (dictionary) after the filter stopwords (English) and before Filter Tokens (by Length). It seems to ignore my list of stopwords (dictionary). I've tried using a csv and txt file for stopwords (dictionary) but the stopwords still show up in the output. I've set preference rapidminer.general.encoding to UTF-8. All the files should be in English. Any ideas?
<process version="5.2.003">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process">
    <process expanded="true" height="415" width="547">
      <operator activated="true" class="read_excel" compatibility="5.2.003" expanded="true" height="60" name="Read Excel" width="90" x="45" y="30">
        <parameter key="excel_file" value="E:\R-2.14.0\bin\i386\tickets.xls"/>
        <parameter key="imported_cell_range" value="A1:A748"/>
        <parameter key="first_row_as_names" value="false"/>
        <list key="annotations">
          <parameter key="0" value="Name"/>
        </list>
          <parameter key="0" value="Rationale.true.text.attribute"/>
        </list>
      <operator activated="true" class="text:process_document_from_data" compatibility="5.2.001" expanded="true" height="76" name="Process Documents from Data" width="90" x="179" y="30">
        <parameter key="keep_text" value="true"/>
        <parameter key="prune_method" value="absolute"/>
        <parameter key="prune_below_absolute" value="10"/>
        <parameter key="prune_above_absolute" value="700"/>
        <list key="specify_weights"/>
        <process expanded="true" height="434" width="557">
          <operator activated="true" class="text:transform_cases" compatibility="5.2.001" expanded="true" height="60" name="Transform Cases" width="90" x="35" y="45"/>
          <operator activated="true" class="text:stem_snowball" compatibility="5.2.001" expanded="true" height="60" name="Stem (Snowball)" width="90" x="154" y="49"/>
          <operator activated="true" class="text:tokenize" compatibility="5.2.001" expanded="true" height="60" name="Tokenize" width="90" x="40" y="144"/>
          <operator activated="true" class="text:filter_stopwords_english" compatibility="5.2.001" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="45" y="255"/>
          <operator activated="true" class="text:filter_stopwords_dictionary" compatibility="5.2.001" expanded="true" height="60" name="Filter Stopwords (Dictionary)" width="90" x="179" y="300">
            <parameter key="file" value="E:\Rapid Miner\RapidMiner5\Stop_Dictionary05082012.txt"/>
          <operator activated="true" class="text:filter_by_length" compatibility="5.2.001" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="270" y="225">
            <parameter key="min_chars" value="2"/>
            <parameter key="max_chars" value="9999"/>
          <operator activated="true" class="text:generate_n_grams_terms" compatibility="5.2.001" expanded="true" height="60" name="Generate n-Grams (Terms)" width="90" x="380" y="165">
            <parameter key="max_length" value="1"/>
          <connect from_port="document" to_op="Transform Cases" to_port="document"/>
          <connect from_op="Transform Cases" from_port="document" to_op="Stem (Snowball)" to_port="document"/>
          <connect from_op="Stem (Snowball)" from_port="document" to_op="Tokenize" to_port="document"/>
          <connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
          <connect from_op="Filter Stopwords (English)" from_port="document" to_op="Filter Stopwords (Dictionary)" to_port="document"/>
          <connect from_op="Filter Stopwords (Dictionary)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
          <connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Generate n-Grams (Terms)" to_port="document"/>
          <connect from_op="Generate n-Grams (Terms)" from_port="document" to_port="document 1"/>
        </process>
      <operator activated="true" class="correlation_matrix" compatibility="5.2.003" expanded="true" height="94" name="Correlation Matrix" width="90" x="54" y="198"/>
      <connect from_op="Read Excel" from_port="output" to_op="Process Documents from Data" to_port="example set"/>
      <connect from_op="Process Documents from Data" from_port="example set" to_op="Correlation Matrix" to_port="example set"/>
      <connect from_op="Correlation Matrix" from_port="example set" to_port="result 1"/>
      <connect from_op="Correlation Matrix" from_port="matrix" to_port="result 2"/>
      <connect from_op="Correlation Matrix" from_port="weights" to_port="result 3"/>
    </process>
</process>
