I am trying to process a spreadsheet in batches defined by rows having the same ID value.
My test spreadsheet contains 5 rows and 2 columns of the form :
ID Text
1 First row for id 1
2 First row for id 2
1 Second row for id 1
2 Second row for id 2
3 First row for id 3
My objective is to use Loop Values to iterate through this data set once for each unique value of ID and only return the result set of rows for that ID.
When I use Loop Values operator and connect to Data to Document operator, I get the text for all 5 rows for each iteration of ID.
When I connect Loop Values to Filter Examples and apply the attribute value filter, I get the text for the rows that match the specified value for each iteration of ID.
What i want is to be able to do is match attribute value with the loop_value, but I don't know how to specify the condition.
Desired result using example above is to generate 3 output objects :
Loop value 1 should contain text from rows 1 and 3
Loop value 2 should contain text from rows 2 and 4
Lopp value 3 should contain text from row 5
My code is shown below:
<process version="5.1.003">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.1.003" expanded="true" name="Process">
<process expanded="true" height="297" width="575">
<operator activated="true" class="read_excel" compatibility="5.1.003" expanded="true" height="60" name="Read Excel" width="90" x="45" y="30">
<parameter key="excel_file" value="C:\Documents and Settings\bjenkins\My Documents\Test Loop.xls"/>
<parameter key="imported_cell_range" value="A1:B6"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="0" value="ID.true.nominal.id"/>
<parameter key="1" value="Text.true.text.attribute"/>
</list>
<operator activated="true" class="loop_values" compatibility="5.1.003" expanded="true" height="76" name="Loop Values" width="90" x="246" y="30">
<parameter key="attribute" value="ID"/>
<process expanded="true" height="315" width="593">
<operator activated="true" class="filter_examples" compatibility="5.1.003" expanded="true" height="76" name="Filter Examples" width="90" x="112" y="75">
<parameter key="condition_class" value="attribute_value_filter"/>
<parameter key="parameter_string" value="ID=3"/>
<operator activated="true" class="text:data_to_documents" compatibility="5.1.001" expanded="true" height="60" name="Data to Documents (3)" width="90" x="242" y="31">
<list key="specify_weights"/>
<connect from_port="example set" to_op="Filter Examples" to_port="example set input"/>
<connect from_op="Filter Examples" from_port="example set output" to_op="Data to Documents (3)" to_port="example set"/>
<connect from_op="Data to Documents (3)" from_port="documents" to_port="out 1"/>
</process>
<connect from_op="Read Excel" from_port="output" to_op="Loop Values" to_port="example set"/>
<connect from_op="Loop Values" from_port="out 1" to_port="result 1"/>
</process>
</process>
