<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process"> <process expanded="true" height="235" width="346"> <operator activated="true" class="retrieve" compatibility="5.2.003" expanded="true" height="60" name="Retrieve" width="90" x="246" y="165"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="write_excel" compatibility="5.2.003" expanded="true" height="76" name="Write Excel" width="90" x="440" y="155"> <parameter key="excel_file" value="REPLACE_ME"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Write Excel" to_port="input"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process"> <process expanded="true" height="431" width="882"> <operator activated="true" class="text:process_document_from_file" compatibility="5.2.001" expanded="true" height="76" name="Process Documents from Files" width="90" x="179" y="300"> <list key="text_directories"> <parameter key="Free" value="/Volumes/MyBook/Ethometrix/Text mining abstracts/ESVCE Free txt"/> <parameter key="Themed" value="/Volumes/MyBook/Ethometrix/Text mining abstracts/ESVCE Themed txt"/> </list> <parameter key="create_word_vector" value="false"/> <parameter key="add_meta_information" value="false"/> <parameter key="keep_text" value="true"/> <parameter key="prune_method" value="absolute"/> <parameter key="prune_below_absolute" value="2"/> <parameter key="prune_above_absolute" value="999"/> <process expanded="true" height="799" width="917"> <operator activated="true" class="text:tokenize" compatibility="5.2.001" expanded="true" height="60" name="Tokenize" width="90" x="112" y="75"/> <operator activated="true" class="text:transform_cases" compatibility="5.2.001" expanded="true" height="60" name="Transform Cases" width="90" x="112" y="210"/> <operator activated="true" class="text:filter_stopwords_english" compatibility="5.2.001" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="112" y="345"/> <operator activated="true" class="text:stem_porter" compatibility="5.2.001" expanded="true" height="60" name="Stem (Porter)" width="90" x="246" y="75"/> <operator activated="true" class="text:generate_n_grams_terms" compatibility="5.2.001" expanded="true" height="60" name="Generate n-Grams (Terms)" width="90" x="246" y="210"> <parameter key="max_length" value="3"/> </operator> <operator activated="true" class="text:filter_by_length" compatibility="5.2.001" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="246" y="345"> <parameter key="min_chars" value="2"/> <parameter key="max_chars" value="999"/> </operator> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/> <connect from_op="Transform Cases" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/> <connect from_op="Filter Stopwords (English)" from_port="document" to_op="Stem (Porter)" to_port="document"/> <connect from_op="Stem (Porter)" from_port="document" to_op="Generate n-Grams (Terms)" to_port="document"/> <connect from_op="Generate n-Grams (Terms)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/> <connect from_op="Filter Tokens (by Length)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="write_excel" compatibility="5.2.003" expanded="true" height="76" name="Write Excel" width="90" x="514" y="345"/> <connect from_op="Process Documents from Files" from_port="example set" to_op="Write Excel" to_port="input"/> <connect from_op="Process Documents from Files" from_port="word list" to_port="result 1"/> <connect from_op="Write Excel" from_port="through" to_port="result 2"/> <connect from_op="Write Excel" from_port="file" to_port="result 3"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process> [ /code]
